Best Way To Lower Cls
Old Feb 13, 2007 | 01:02 AM
SAMSSONZ's Avatar
OO7 CLS63///G55TANK ///S80-T6///R1///R6
Wats The Best Way To Lower The Cls, Any Suggestions?
Old Feb 13, 2007 | 01:59 AM
AMG_55's Avatar
mymbonline
renntech elm
Old Feb 13, 2007 | 02:57 AM
allied107's Avatar
07 CLS550 & 05 E55
I used MB linkages to lower my car there is also star diagnostic, lower modules like brabus, renntech. There are many was but I don't know that advantages and disadvantages.
Old Feb 14, 2007 | 04:03 PM
larryv's Avatar
06 CLS, 06 Chevy ZQ8, 07 Chevy TBSS (05 BMW M3,SOLD, 02 BMW 4.6,SOLD.
I used Adj lowering links (pic)
No problems and easy to install.
Old Feb 14, 2007 | 04:16 PM
hollywoodtrash's Avatar
Try MKB lowering kit. I've heard Renntech's lowering kit works well also.
Old Feb 14, 2007 | 04:19 PM
Griffin337's Avatar
E55
How much and where do you get them?
Old Feb 14, 2007 | 04:33 PM
larryv's Avatar
I purchased them @ F1 Motorsport in Hollywood Ca. 818-755-9805. I bought them back in Nov 05 and they were $200.00. Good Luck
Old Feb 14, 2007 | 04:46 PM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
How does this kit work?
Old Feb 14, 2007 | 05:35 PM
newton22's Avatar
BMW E39
Those look like the standard S-class rear links. You are using those for the rear right?
It's personal preference. With the Star Diagnostic, you will NOT be able to adjust whenever. With links and module (mildly modified modules with extending knobs), you WILL be able to adjust on the fly. With links, you will have to lift the car and adjust the sensor links physically. With the modified module, you will be able to adjust inside the car (best and laziest method IMO, but also most expensive). I'm on modified stock links.
Old Feb 14, 2007 | 05:42 PM
amgbenz55's Avatar
06 CLS55 - Silver/Black
who's got the best deal on a renntech elm?
Old Feb 14, 2007 | 08:21 PM
larryv's Avatar
newton22, i am not sure if they are from the S class, they are used in the front only and the rear sensor (1) needs to be adj down slightly which will lower the rear. The rear sensor hole will have to be dremeled downward so the sensor can slide down. Very easy!
Old Feb 17, 2007 | 01:07 AM
SAMSSONZ's Avatar
I Ve Done The Washer Method On My Sl And Ive Seen Plenty Of Other Benzs Also Dropped The Same Way. So Why Would I Need To Purchase A Lowering Module???
