Dyno mode and 030 performance package LSD
Old Apr 26, 2007 | 12:22 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Put my 06 CLS 55 into Dyno mode to stretch its legs. Since I have LSD I had very limited smoking of the tires. I think what is happening, is that ESP sits on top of the LSD and does double duty. When ESP is really programmed off as it is in the Dyno mode, I really get the kick of my full HP while keeping the rubber on the road, just like in the old days before all the car electronics.
With no clocks or stop watches, my unscientific feeling is that I got faster 0-60s and beyond in the Dyno mode versus non Dyno or ESP on or off.
Has anyone with the 030 performance package (LSD) experimented with this? I would like to know.
Old Apr 26, 2007 | 12:41 PM
sprins's Avatar
G55, SLS, smart eq
I had the 030 LSD installed after two years of SL55 ownership. The difference is amazing, more grip and less ESP/traction-control interference. It seems as though ESP plays nice with the LSD (I asked AMG, and they haven't updated ESP software due to LSD install, they also said it would play nice together).
Of course with ESP off (meaning almost off, but traction control is definitely off) I can still smoke my tyres, albeit with two evenly painted rubber lines
Haven't tried in dyno-mode.
Old Apr 26, 2007 | 04:44 PM
siswati's Avatar
'10 Panamera S, '06 AMG CLS55, '07 Miata MX5, '02 MB SPRINTER, '99 Spec Miata Race Car (2X)
Hi m_berman
I have the CLS55 with 030 - one of the first ones to arrive in the US. I ran it almost immediately at Moroso.
you can read about my experience and see the videos here at https://mbworld.org/forums/c219/165085-amg-cls55-vs-amg-cls63-moroso-drag-strip-results-sept-29th-2006-a.html
The burnout issues had several others chiming in on the ability to do a burnout - you will see that I had very different experience in the E55 where I was able to do a stationary burnout with the ESP off, but in the CLS I had to go to DYNO mode. (Note that in my CLS55 with the ESP off and the front tires just rolling ever so slightly, I can do a continuous burnout - but with the front wheels stationary it just cuts the power even with ESP off - my E55 could sit there all day long just smoking the rear tires without ever moving an inch in ESP off mode))
As for more power in DYNO MODE, I doubt it. As for launching, you have to feather in the throttle - YOU CANNOT JUST MASH IT - let the tail sit before you start mashing it otherwise you will be sideways staring at the concrete walls. Not fun at all!
Old Apr 27, 2007 | 09:42 AM
roadking40's Avatar
How do you get the car in dyno mode? I have a 06 55.
Old Apr 27, 2007 | 11:48 AM
m_berman's Avatar
DYNO mode disables ESP, BAS and ABS
This was discussed over time on this board, but I clipped boarded FYI:
The DYNO mode disables ESP, BAS and ABS.
This is how you get into the hidden menu in the MFD.
FIRST MAKE SURE YOUR MDF SCREEN IS CURRENTLY DISPLAYING THE OUTDOOR TEMPERATURE, THEN:
1. Insert your key and turn to position 1.
2. Press the trip odometer reset button three (3) times.
3. The first screen you will see on the MFD is the battery voltage in the following format - UB: 12.0 V
4. Press the UP arrow button on the steering wheel.
5. You will now see other information such as Software Version, etc. If you turn the key to position 2 you will get a oil reading by QTS and other info will appear.
6. If you want to put the car into DYNO mode which will disable ESP and BAS, leave the key in position 1 and hit the up arrow until you see the screen that says "ESP Dynamometer Test".
7. At this screen use your + or - steering wheel button to turn this mode ON.
8. You will get some malfunctions due to ESP, BAS, etc. being off, but this is not a problem and they will go away once you disable the DYNO mode.
9. You can start you car now to DYNO it without all the electronic wizardry getting in the way.
CAUTION: DO NOT DRIVE LIKE THIS OR BAD THINGS MAY HAPPEN. ESP, BAS, ABS are desirable when driving
10. To exit out of DYNO mode, simply turn your car off then back on and it will reset to normal.
Old Apr 30, 2007 | 01:14 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Thanks for sharing
now here comes the question do i dare use it and hammer it
I believe common sense will prevail and fear of killing my rubber and the cost of new ones will sink in
great info non the less
Old Apr 30, 2007 | 01:26 PM
m_berman's Avatar
Originally Posted by Zod
Thanks for sharing
It's not the rubber to be concerned about--its your flesh!
Very dangerous to drive pedal to the metal in dyno mode.
Old Jul 23, 2007 | 03:30 AM
Zod's Avatar
Zod
I have to agree... tried a ESP off full mash of pedal.
was at traffic light racing a mate of mine in his subru STI.
I am like hehe lets try all out, never done it before.
SO off I go turn AC off, turn esp off S mode suspension 2... wait for traffic light to hit green 1…2….3…MASHHHHHHH pedal
Tires were screaming and whole car was just angry its ok.. it will hook up now I tell my self.... first into second, tires still screaming..... Its ok I tell my self, it will hook up now..... as I continue to spin the tires I feel my self going sideways.......its ok its just a little wiggle....omg I am really going side ways BRAKEEEEE!!!!!!! and I was an inch from the Pavement of death!
Lesson learned:
Never turn esp off and mash pedal..... do not want to even think of dyno mode
Friend comment was WTF was that , people at the traffic light who I met up with at next set of lights, gave me the stare of ARE you sain ! and there jaws were left open
friend said all he saw was a cloud of smoke and screaming tires
all I know now is esp off botton stands for… well do you feel lucky punk well do ya!
Just thought I would share
Old Jul 23, 2007 | 05:28 AM
amalamud's Avatar
CLS55 06 (K4, LSD), Range Rover Sport 06, Bentley Flying Spur 07
Old Jul 23, 2007 | 08:09 AM
juicee63's Avatar
2011 twin turboed prius
It took you 3 months to answer the post?
Or 3 months to get into dyno mode LOL...
Sounds like a hairy run , be safe , have fun
Old Jul 23, 2007 | 06:13 PM
rslpartners's Avatar
Interesting, I didn't know one could install this after the fact.
Was it done at a mbz dealership? or did you have to bring it to a high performance shop?
