need some help please!!!
Old Apr 26, 2007 | 08:37 PM
CLS63JD's Avatar
2008 CLS63
Hey everyone, I'm picking up my CLS63 on Monday and I would like to change the amber reflectors on the front bumper to clear reflectors. Those amber reflectors are way too ugly for such a great looking car!!! Any help is greatly appreciated!!!
Will post some pics once I pick it up....
Old Apr 27, 2007 | 01:31 AM
yahya's Avatar
CLS 500, Infiniti FX 35
Congrats, and welcome.
I got mine from ebay for abour $40.
Old Apr 27, 2007 | 02:54 AM
Kevin M.'s Avatar
CLS 55
yep ebay it is.. here you go..
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
Old Apr 27, 2007 | 10:58 AM
CLS63JD's Avatar
2008 CLS63
Thanks a lot, I appreciate the responses!! I used the link in the post and I will definately purchase the clear reflectors. Any tips on the install?
Old Apr 27, 2007 | 02:46 PM
Htowncls's Avatar
CL63
DO A SEARCH ON REFLECTORS OR SIDE MARKERS HERE.. YOU WILL FIND MORE INFO.. THE BOTTOM LINE IS YOU JUST PULL THEM STRAIGHT OUT WITH YOUR HANDS, TWIST BULB HOUSING OUT, TWIST IT INTO THE NEW UNIT AND PUSH BACK IN.... IF YOU CANNOT PULL THE OEM MARKER OUT WITH YOUR FINGERS USE A SCREW DRIVER ON ONE SIDE TO PULL THEM OUT.. DONT PRY BUT PULL.. SCREW DRIVER RIGHT BEHIND THE BACK OF THE MARKER AND PULL OUTWARD MAKING SURE YOU ARE NOT PRYING BACK AGAINST YOUR BUMPER AND PAINT JOB..
GOOD LUCK
Old Apr 27, 2007 | 09:10 PM
CLS63JD's Avatar
2008 CLS63
Thanks for the great info Htowncls!!! I was wondering whether I would be able to just pop them out amd now I know... Thanks again!
Old Apr 28, 2007 | 12:26 AM
Dogshine's Avatar
CLS55
you can pull the plastic off next to the fog light and put your hand inside and pop it out that way too...
Old Apr 28, 2007 | 12:34 AM
Dogshine's Avatar
CLS55
i pulled it off the reflectors first, but then i decided to put yellow lights in them and the ebay reflector's plastic clip isn't as flexible and i didn't want to break it, so i removed the grill and put my hand up in there to pop it out the second time.
