CLS55 Intercooler Pump
Old May 7, 2007 | 11:43 PM
Tomcls55's Avatar
I know there is a High failure rate for these pumps, but how can you tell if it has failed? are there any signs how many miles before they go out? can you get into a dioganistic ( spelling) mode and find out? Anything to check before taking it to the dealer?
Tom
Old May 8, 2007 | 05:43 PM
CLS55-AMG's Avatar
Blue 06 CLS55
i've just had that problem with my car,, u sure will feel it, the car will loose lot of power and th sc will go off.. i had it around 25k km but it really depends on how often u hit the car hard.
Old May 8, 2007 | 07:28 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
So...There is no CC message--just loss of power. It must trip a code or something with all the electronics.
How does the Dealer diagnosis the loss of power?
Old May 9, 2007 | 08:44 AM
ItalianStallion's Avatar
R35 GT-R, EvoX
Just tell them that your supercharger keeps shutting off and you have heard from others who have these same engines that its the faulty pump that is causing this. Thats what they did for me, they replaced it right away with no questions.
Old May 9, 2007 | 02:17 PM
clos's Avatar
06 CLS55
Same Intercooler problem!
I'm experiencing the same problem, loss of power I don't have time to take it to the dealer now. This seems to be the general consensus of the cause though.
Good luck if you happen to make it to the dealer before me please post how the dealer handled it and if you feel a differnce after it was replaced.
Old May 9, 2007 | 05:29 PM
chutia's Avatar
06 CLS55 AMG-all options sans Distronic; Carrera4S; 07 M5;Lexus GS300
Luckily I do not have this problem (yet....hopefully not ever). However, I was at the dealer this morning on an unrelated matter and asked about this. For what it's worth, there is apparently newer part# for the 07 than the 06 intercooler pumps and regulator that is supposed to be a "fix." Just FYI for those unfortunately having this issue.
Old May 15, 2007 | 11:06 PM
Tomcls55's Avatar
So when the pump quits does the S/C not engauge at all? or just a lower setting?
Old May 15, 2007 | 11:48 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
The stock bosch pump has a poor longetivity and efficiency. The car will feels like it loses "100hp or more". One way you can tell is @ the dyno, or do couple of spirited runs and you will feel the supercharger disengages all the time.
