X-Pipe!!
Old Oct 23, 2007 | 07:02 PM
dsb's Avatar
dsb
'06 slk55
Originally Posted by Vadim@GMGRacing
Oh, lets see TQ converter balooning form excessive pressure, main thrust bearings failure if transmission is dropped into drive at high RPMs, and many other potential problems.
I understand if it's shifted at a high rpm it will cause damage. However, is it still bad if you simply coast back down to a dead stop and engage drive at 1k rpm?
Old Oct 24, 2007 | 08:04 AM
jclouis27's Avatar
Cls55 AMG
Will the X-Pipe work on the CLS55 AMG ? If so can I buy one from you guys. Please let me know how I can order it.
John
Old Oct 24, 2007 | 09:47 AM
Vadim @ FD's Avatar
S600TT, R350
Yes, the X-pipe will work on both E/CLS63s, as well as E/CLS55s.
Old Oct 24, 2007 | 10:41 AM
vegastrashed's Avatar
2007 E63 AMG
Vadim,
What is your opinion about replacing the secondary cats with x-pipe and resonator with straight pipes? I've already replaced my resonator with straight pipes on the E63. It was pointed out to me that replacing the resonator with x-pipe is redundant since the stock exhaust has a H-pipe crossover before the secondary cats. Your thoughts?
Old Oct 24, 2007 | 12:11 PM
Vadim @ FD's Avatar
S600TT, R350
vegastrashed:
Since you have already replaced your resonator with straight pipes, I would recommend replacing secondary cats with an X-pipe. It will not be a direct bolton, some additionall fabrication will be required.
Old Oct 24, 2007 | 12:51 PM
2007 E63 AMG
vegastrashed:
Thanks for reaffirming that what I'm planning in doing is okay.
Will the x-pipe that you have for sale fit the section 1 (secondary cats)?
Old Oct 24, 2007 | 12:59 PM
  #32
jclouis27's Avatar
Cls55 AMG
how can I go ahead and order the X Pipe ? Please let me know
Old Oct 24, 2007 | 01:05 PM
  #33
Vadim @ FD's Avatar
S600TT, R350
Not directly, you will need two 45 deg. 3'' sections to mate it to the downpipes. If you have a good muffler shop, they can get it done for you.
You can call me directly at 714.432.1582.
Thanks,
Old Oct 24, 2007 | 01:44 PM
  #34
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Originally Posted by vegastrashed
Vadim,
Interesting, H (stock) or HX (rarfinancial) or X (vegastrashed), I though the H and X had about the same effect in HP. but I guess this is about the sound and not redundancies.
Old Oct 24, 2007 | 09:16 PM
  #35
newguycls55's Avatar
what are the effects if we remove the secondary cat? will it throw a Cel, and most muffler shop told me they wont do it.
Old Oct 24, 2007 | 10:35 PM
  #36
2007 E63 AMG
CEL only comes on when you remove the primary cats. If you remove the secondary cats you will most likely lose back pressure b/c you're removing the stock crossover that's integrated with the secondary cats and not to mention illegal. I intend to replace the secondary cats with a x-pipe thus negating the lose of back pressure. Anyone, please correct me if I am incorrect at this. There are shops that will remove the secondary cats if you know where to look and show them $$$.
Old Oct 24, 2007 | 11:08 PM
  #37
i have spoken with several different shops, some have issues because one side of the pipe is round, and the other is oval shape. what are the benefit of removing the secondary cat and replace with an X pipe?
Old Oct 25, 2007 | 12:04 AM
  #38
rarfinancial's Avatar
CLS63
Vadim,
I replaced the res with X-pipe for sound only no hp gain. What are you trying to gain by replacing the secondary cats with X-pipe? Also is the H on the stock system for smog or hp gains? Maybe cap off the stock H and install the X-pipe If your removing one set of cats for hp gains why not remove them all for more gains and find some o2s simulators
Old Oct 25, 2007 | 01:43 AM
  #39
2007 E63 AMG
Here's the way I see the stock 63 exhaust system. The primary cats, secondary cats, resonator and stock mufflers are too restrictive for expelling the exhaust gas. My plan is to keep the primary cats for now, maybe replaced by sports cats in the future. The secondary cats with H-pipe crossover will be replaced by x-pipe. The resonator has already been replaced by straight pipes. With this set up the exhaust gas will flow better. Yes, I'm well aware that to realize the most gain in the exhaust system would be to change out the headers to either short or long headers. But, I'm doing the exhaust system in phases. I'm doing the headers last b/c it's the most expensive. As for why there is a stock h-pipe, it's to prevent the loss of back pressure. Anyway, I hope I'm not talking outta my **** here.
Cliffnotes: replacing secondary cats with x-pipe will allow for better flow of exhaust gas plus some weight savings, however small it might be.
Old Oct 25, 2007 | 05:06 PM
  #40
StealthAuto's Avatar
Cobra/E55
Just speaking from personal knowledge/experience, an h-pipe will provide more torque down low (due to backpressure I believe) whereas an x-pipe will provide more horsepower in the higher rpms by allowing increased air flow. With any supercharged Mercedes, given the type of blower MBZ uses, I suggest going with an x-pipe instead of an h-pipe because there's already plenty of torque in the lower rpms.
Old Dec 29, 2010 | 04:41 AM
  #41
amgking22's Avatar
04 e55 amg
im a noob dumb qestion but how do create a post pleasee help
Old Jan 4, 2011 | 01:42 AM
  #42
Viet_Amg408's Avatar
Pinto
Originally Posted by cmergonoto
if i replace the secondar cats with x pipe, am i gonna see a decrease in the low end tq? how much does the x pipe in replacement for the secondary cats cost?
i replaced my secondary cat and resonator with straight pipe, no crossover..
i notice low-end torque is lost but i feel high end engine pull better..
Old Mar 2, 2015 | 11:20 AM
  #43
atticuskd's Avatar
cls 6.3
Do you have any xpipes left? If so how much? 817.637.2318 or atticuskd@gmail.com
Thanks,[/QUOTE]
