New Dyno Results
Today I dynoed once again. Below are the results:
First run....376 in third gear
Second run...382 in third gear
Third run...402 in fourth gear
Fourth run...397 in fourth gear
Here is some relevant information that some of the more educated individuals to dyno will be able to use:
Inside temp of dyno room: 88.5 degrees
Barometric Pressure... I think 29 degrees
Oil temp...112 degrees celcius
Altitude...Approximately 1800 above sea level....Dallas area
Dyno was done in Manual Mode shifting first gears at around 3500 RPMS and final gear to 7400.
Dyno was done with car in dyno mode
I have removed my carbon filters and had an ECU upgrade by Renntech. I still think that my numbers should be better, but taking in the above factors, I am not sure. Please Help!!!!!!!!!!
D3
D3
my car = fully stock
stock cars get 400-420
you car is supposed to get 430-450 with ECU
Oil at 112c ? From reading the posts on the forum these cars run best at low oil temps. But before you do any retune please go to the track, 1/4 mile see what it does. I don't like dynos ..
user error? to hot? no ram air? see what real #'s you get. Call Renntech talk to Bob about it. Please go to the trackToday I dynoed once again. Below are the results:
D3
Are these numbers SAE corrected? Are they DA corrected?
Almost 90 degrees air temperatures combined with 112 C oil temperatures and already 1800 ft elevation can easily rob you of 20 to 30 hp.
Just to give you an example, last time I was out on the track, I ran the car at different oil temperature levels. When oil temps were around 60 C, I ran 12.7s but then when oil temps went back up to 105 C, the best I could run was 13.1 seconds. As you can see, that's almost half a second slower in a matter of 5 minutes
I would say half a second slower is a lot of hp loss
So yes, DA and altitude will reduce hp.Dynos only help you to determine effectiveness of mods not how much hp your car makes. I've seen the same car dyno at different shops (my C32 stage 2) with 27 hp difference (and that's only on a 300 hp car, you're dynoing a 500+ hp car, so I'd expect up to 40 hp difference).
The only way you'll be able to tell if ECU helped your car is by running the car at the track a couple of times and compare your results to a stock 63 car. For example, Trez's 63 dynos at 440 hp while Juicee's car dynos at 401 hp, but at the track, both car ran the same numbers. Does that mean a 40 hp increase in Trez's car does nothing?
Try this.......
1) Dyno the car on a very cold day (40 to 50 degrees)
2) Drive the car very hard before you dyno it, so that ECU will adapt to aggressive driving.
3) Let the car cool down before your first dyno run. Make sure oil temperatures are at 50 C.
4) Wait until the car fully cools down between runs.
Sorry for the long post, but I'm trying to look at the whole picture here and don't worry, with the help of all members here, we'll get this figured out....
Thanks so much for all the help. Don't have any updates yet. The weather here in Texas has been beautiful, so it might be a month or so before I can get a day at the temps you recommended. I haven't had a chance to get it to the track and time a quarter, but when I do, I will make sure and let the oil temp be as low as possible. Thank you once again so much for all the help.
D3
Try this.......
Try this.......
50c is not normal oil temp and never will be
letting car cool down for every run is also not normal
To me it feels that you are doing all that is in your power to the max the best performance out of the car and is not the consistent performance the car will run at i feel
Good to try it for fun though, just to see
The reason I said 50C is because oil temps in our high compression engines rise very quickly and by the time he lines up in the staging lanes or start a dyno pull, the temperatures will easily be in the 60s again. But if outside air is very cold, oil temps play less of of a role.
Weather effects all cars, yes this is why we have more races in winter time
but the thing about the weather is everyone is effect so
but oil will never be at 50c in normal everyday driving...
