High rate of oil consumption!
Old Mar 15, 2008 | 06:34 PM
CLS63JD's Avatar
2008 CLS63
Hey guys, over the last 2,000 miles my car has been burning oil at a rate of 2 to 2 1/2 quarts every 500 to 700 miles. I brought the car in to have an oil consumption test performed. Does anyone have any experience with this issue? I can understand burning about a quart of oil every 1,000 miles b/c of the 63 motor, but over 2 quarts in less than 1,000 miles is a bit off in my opinion. Any advice, info, help, feedback is greatly appreciated guys!! What should be the correct oil consumption per 1,000 miles???
Old Mar 15, 2008 | 08:33 PM
sick430's Avatar
CLK Cabrio
what oil are you using. what is the current milage on your car? when was your last oil change?
Old Mar 15, 2008 | 08:40 PM
Jocampo's Avatar
06 CLS55 AMG
Tom posted about this issue in this post, towards the middle
https://mbworld.org/forums/c219/232610-looking-buy-cls-55-a.html
it also references another post of other 63 engine's consuming oil, but stopping after a certain period. check it out.
Old Mar 15, 2008 | 09:40 PM
CLS63JD's Avatar
2008 CLS63
My car has 9,800 miles, I changed the oil 1,500 miles ago, and I use the recommended oil and it is done by the MB dealer.
Old Mar 15, 2008 | 09:47 PM
CCR's Avatar
CCR
Radical
something is wrong, 1 qt per 1k is average
Old Aug 26, 2013 | 04:35 PM
MadHatt3r's Avatar
CLS55 AMG
Is the 1qt per 1000 miles the average consumption of the supercharged CLS55 motor? Just want to ensure my AMG doesn't have a problem. I'm going through a quart every 1000 miles. Car has 71000 miles on it and runs perfect. No oil leaks so I know it's a consumption thing.
Old Aug 28, 2013 | 09:07 AM
1SickCLS's Avatar
CLS55 AMG
Ive got 96k on mine and I put a quart in about 1700 miles ago and its telling me that I should put another quart in to reach max level.
Runs like a beast, so I guess its normal? Just carry a quart around with you in the trunk.
Old Aug 28, 2013 | 10:24 AM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I heard 1QT is 500 miles.
Old Aug 28, 2013 | 12:26 PM
Quadcammer's Avatar
96 and 08 911 turbos
that is absolutely not ok. oil consumption at that level is a serious problem.
Old Aug 28, 2013 | 02:35 PM
MadHatt3r's Avatar
CLS55 AMG
At which level Quadcammer? 1pt per 1000-1500 miles? Or the 1qt per 500 miles as was mentioned after my question?
