Check eng. oil level when next refuelling ?
Old 04-10-2008 | 01:22 AM
yunica99's Avatar
C320 sport sedan (2004.05), CLS 63 AMG (2007.01), E 63 AMG (2009.10)
I always see this message in these days.
If I drive very tough I don't see this message but under normal driving
I always see this message.
so I went to dealer and add 1 liter of engine oil.
but as soon as I left dealership I saw it again.
So I went back and check oil level again.
and the oil dipstick in engine room it says ok (it's just under the MAX line)
Now I'm confused which one is not working properly.
oil level or pressure sensor or dipstick?
Dealer will replace two things in two weeks for free(under warranty).
Does anyone have any idea ?
Old 04-10-2008 | 08:57 AM
hatem's Avatar
cls 55 amg, clk 320
i had the same problem, when i took it to the service center, i found out that apparently there were around four broken oil seals, which were changed under the warranty.
Old 04-10-2008 | 08:58 AM
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
I got that 2 times before too! I need to take mine by the dealer to have them check the oil. It comes and goes I only have 9K miles on the car
Old 04-10-2008 | 10:34 AM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
I get it all the time, now I just ignore.
Old 04-10-2008 | 11:09 AM
Blood Doctor's Avatar
'10 Tesla Roadster, '06 AMG CLS 55; '00 SVT F-150
oil leaks...
I haven't gotten the message yet.
But my mechanic buddy who checks my car from time to time, always looks and says that all Benz models are notorious for oil leaks from bad gasket designs & other seal problems.
This week I noticed a few drops of oil under my car too... Guess I better take it in to a service center before the warranty ends this year.
Take it from the Blood Doctor, oil is the life blood of your car... don't ignore it, get it fixed under warranty.
- Ed
Old 04-10-2008 | 01:29 PM
joeybenz106's Avatar
2007 cls 550
well i know on my 550 there was an oil leak from my cam cover. i only noticed it due to the fact that my car is in a storgage unit all winter so i pull it in and out and seen oil on the ground. i would get that checked out. also i know the 63 burns some oil
Old 04-10-2008 | 01:34 PM
Shane24's Avatar
CLS 63
I think that when people say that the 63 burns some oil is an understatement. My CLS 63 burns about 1 qt every 1000 miles lately. I have about 9500 miles on it and have topped it up with 6 quarts since new. I do stomp on it every once in a while though and definitely dont drive like a grandmother.
Old 04-10-2008 | 02:28 PM
CLS63JD's Avatar
2008 CLS63
My car is at the dealer right now because my CLS63 has been consuming between 1-2 quarts of oil in less than 1,000 miles. They can't find any leaks or fault codes... Always be careful when it comes to oil and you will not always see a leak if there is something wrong as in my case.
Old 04-10-2008 | 07:50 PM
Centurion's Avatar
a car that gets very poor gas mileage.
S. Cali owners...
What viscosity oil are you currently using with your 63 motor?
I've been using 5W-30 with my other cars.
I remember this thread https://mbworld.org/forums/showthrea...ght=oil+engine and apparently 5W-30 Pennzoil full synthetic is one of the "approved" oils for the 6.2L motor.
Anyone use this or have thoughts on others?
Old 04-10-2008 | 08:41 PM
yunica99's Avatar
well as far as I know..
"only Xw-40 and MB Sheet 229.5 approved oil" is the right one for our 63 AMG.
every time I look up the MB Sheet 229.5 oil list there's an advice that " *Not approved for use in AMG engines." guess what, Pennzoil European Formula Ultra 5W-30 is approved by MB Sheet 229.5 but not for our AMGs.
So I think Mobile 1 SuperSyn European Car Formula 0W-40 is the one.
anyway, Are there any differences in between Normal Mobil 1 Ow-40 and Mobile 1 SuperSyn European Car Formula 0W-40 ?
I'm pretty sure My dealership uses Normal Mobil 1 Ow-40.
If it's not the same one I'm secrewed.
Old 04-11-2008 | 11:09 AM
Centurion's Avatar
The Mobil.com/USA website lists only one type of Mobil 1 0W-40 which happens to be the "European car formula" in their extensive list of oils.
I also found this product info page regarding the European Car Formula, http://www.mobil.com/USA-English/Lub...il_1_0W-40.asp.
I think for the North American market there is only that one type.
Old 04-11-2008 | 08:15 PM
yunica99's Avatar
Centurion thanks alot~
you are the man !!
Old 04-11-2008 | 09:46 PM
turbotom1's Avatar
SL63
I just ignore it as long as the level on the dip stick is above min.
63's are oil hungry b's, eh
Quick Reply: Check eng. oil level when next refuelling ?
