CLS63 engine heat?
Old May 23, 2008 | 10:51 PM
Ak63's Avatar
07 CLS 63
Thanks for the clarifications. Have a good weekend.
Old May 23, 2008 | 11:07 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Coolant temp for a 63 engine runs aroun 90-105C, 110-115 on track days.
The important number is the engine oil temp, which can be displayed on the dash along with the selected gear as the previous picture shows. The normal oil temp on these cars is around 100-120C. There is an additional oil cooler with an auxilary cooling fan which comes on around 118C and above (depending on model, model year, software etc). This fan is audible when it operates and does keep oil temps under control and low speeds/high loads.
Track days you may see upto 140C oil temp.
If the engine overheats there will be a reduction in power by the ECU and warning messages.
Old May 24, 2008 | 01:55 AM
lexaltezza's Avatar
08 CLS63
Wow thanks for the great information. That auxilary cooling fan would explain the vacuum like sound I hear.
