Tailight swap to the 09, is it possible?
Old Nov 22, 2008 | 06:13 PM
duc&tlrsammy's Avatar
Benz and Beemers
I was wondering if anyone here has installed, or tried to update the tailights on a 2007 63 to the 2009 style? Is it a direct plug and play?
Old Nov 27, 2008 | 09:00 PM
Benz and Beemers
Anyone?
Old Nov 28, 2008 | 01:57 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
apprently i was told recently it is and is a direct swap.
you need the part numbers of both left and right tail lights.
I have not seen it done, only going by recent word of mouth that electroincly nothing stopping it to work. I would go with a test fit and if it works buy deAl
other option would be to find any crashed 09 cls and get the lights off it
Old Nov 28, 2008 | 08:26 AM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
They will not work. There is somethng extra that needs to be done to get them to work. They system will not recognize the leds. I want to do this mod also.
Old Nov 28, 2008 | 10:40 AM
SUNILP's Avatar
2015 E250D
Most likely a replacement of the rear SAM module will be required.
Old Nov 29, 2008 | 12:32 AM
NJBoy115's Avatar
2006 CLS55 AMG President Edition
I've been curious about this for a while too...I just saw a 09 CLS63 at night with the new LED tail lights and it looked SICK!!!
I want to upgrade!
Old Dec 2, 2008 | 07:13 PM
jagata's Avatar
S6 LP640 E500
I've seen many guys use resistor to fool the computer when they convert to led, would'nt that work in this case as well?
Old Dec 3, 2008 | 01:29 PM
SAMSSONZ's Avatar
OO7 CLS63///G55TANK ///S80-T6///R1///R6
The main concern is the dimensions, Other than that it should be fine. As for the L.E.D.s, they use less power so it shouldn't be a problem. And a resistor should fix it if there is.
Old Dec 3, 2008 | 09:36 PM
NJBoy115's Avatar
Can the new 2009 side mirror housings be replaced as well???
The new "V" shaped blinkers look pretty cool!
Old Dec 10, 2008 | 07:12 PM
trboda6's Avatar
I have an e60 530i bmw currently on here because i will own a cls55 in a few weeks... basically what you want to do requires a certain splitter or a plug morelike a resistor dont know exactly what it is but the BMW guys are doing it to convert to the new 09 5 series tails which are led's .. someguy created the splitter dont know if he makes them for the merc.. but im sure if contacted he may.. its $ for him.. this can be found on e60.net
im being lazy and dont feel like searching but i know it can be done with that thing that the BMW guys are using to accomplish the 08/ 09 rear tails installed with no error codes.. hope this helps..
Old Dec 10, 2008 | 08:43 PM
NJBoy115's Avatar
Thanks! I'll check that out
Old Dec 11, 2008 | 12:32 AM
turbotom1's Avatar
SL63
Exclamation AMG private lounge response
This question was on the private lounge for 55 to 63 swap.
I'll ask them what's involved for an 07 to change over to LED lights.
"With the facelift from CLS 55 to the CLS 63, not only were the LED's changed, but also some technical components. Due to this fact, it is not possible to use the CLS 63 AMG tail lights for the CLS 55 AMG.
Best regards,
AMG Private Lounge Team"
Old Dec 15, 2008 | 08:54 PM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
these are parts # of new SAM and cable sets
they are more than 600 euros but i can make a great discount
I have also another full rear 2009 edition cable set that the MBService tried to replace.. don't remember how much ..I paid on a forfait basis
WORTHLESS ...still as it was here https://mbworld.org/forums/2980956-post18.html
but today begun playing again a
went with man to the show room for checking the positioning and how each lamp works in the new tail light ... interesting that the two rows of leds magnify when pressing the stop
.. he worked on it all day , he said me its more difficult than expected.. till this evening side light, turn light and fog were already working.
Stop lights are more difficult .. but I'm confident
Old Dec 15, 2008 | 11:23 PM
NJBoy115's Avatar
Best regards,
Ya, I saw that on there too...It's a real bummer that they cant be used on the 55's.
Old Dec 17, 2008 | 03:34 AM
dyno's Avatar
can anyone find a pic with new rear lights on, without stop pedal pressed, PLEASE !!
Old Dec 19, 2008 | 12:08 PM
dyno's Avatar
thanks in any case .. don't need anymore
I had to check how those two rows of leds acting both as city lights and as stop lights, work in a new car.
...because there were 4 leds on bottom row that lighted on only with Stop pedal pressed but they didn't with lights on simply.
......... new thread to come
Old Dec 19, 2008 | 12:14 PM
dyno's Avatar
Best regards,
WHAATT ?
Old Dec 26, 2008 | 11:51 PM
M5toMB's Avatar
CLS63 AMG
WHAATT ?
DAMN!!!
Old Jan 13, 2009 | 01:03 AM
mbz4810's Avatar
08 CLS550 Diamond White 09upgrades
I have a MY08 CLS550 it has the LED on top but smaller quantity ... pretty happy with it; not much different considering the costs.
BUT I am changing my sideview blinkers to the new 09 + POWER FOLDING option thanks to MBENZNL.
PM / email Steve / Wanda if you want it done price is pretty reasonable.
