Swapping Brakes on standard 55
toyota tundra
I have searched the forums and netted a lot of postings but none specific to my question.
I want to know if you can put the 030 brakes on the standard CLS 55? If so, what would it take?
btw...if it helps I have a 2006 CLS55 IWC edition car.
YES YOU CAN,IF YOU 19 INCH WHEELS.SORRY YOU DO HAVE 19 INCH WHEELS
YOU NEED DISCKS , CALIBERS, PADS AND YOU ARE DONE.
EASLY DONE WITH SBC DISCONNECTED.
GOOD LUCK
GOOD LUCK
toyota tundra
cls55 thanks for the response. are the calipers different from the pictures i have seen it looks like it is the same but just offset further for the larger disc.
btw...what is SBC?
btw...what is SBC?
THE CALIBERS ARE BIGGER.
SBC IS (SENSOTRONIC BRAKING CONTROL)The SBC braking system uses a microcomputer to monitor the
car and driver actions. In the event it's needed, such as emergency
braking, the system monitors brake pressure, and applies the
appropriate stopping power necessary, even if the driver doesn't
exert enough power.
SBC features a host of other features as well, including distributing
brake force to different wheels during cornering, to ensure greater
stability in the vehicle as well as maximum stopping power; the SBC
system even dries the brake discs if a film of water forms on them.
SOURCE(http://www.theautochannel.com/news/2...30/151265.html)
exert enough power.
