Ready to purchase Carlsson C-Tronic
Old 09-17-2009, 07:12 AM
  #51
Full Throttle's Avatar
CLS55 AMG
Originally Posted by ocpun
Can you turn off the module and return the cls to its stock height? If so, how? Does your car rub and can you drive in sport 1 or sport 2?
You have already asked if the car rubs here in this thread did you forget?. No you cant return the car back to stock unless you remove the unit.
https://mbworld.org/forums/3717669-post22.html
Old 09-17-2009, 04:21 PM
  #52
ocpun's Avatar
c300
My bad I'm just confused with how this module works while the car is driving and with the CLS's airmatic suspension dampening features and comfort/sport 1/sport 2.
Old 11-27-2009, 07:51 AM
  #53
CLS55 AMG
Just an update 12,000 miles later. The Carlsson is working perfectly aggressive stance no excessive tire wear front or rear.
Old 11-27-2009, 12:30 PM
  #54
Igor180's Avatar
2006 Granite Grey CLS55
Why do you have a COR center cap on your 360Forged wheels?
Old 11-27-2009, 03:13 PM
  #55
Nebster's Avatar
Looking for CLS55 AMG
this is a cute argument between you two.
on a side note how is the adjustability with it. If i wanted to lower it 4 inches at a show or a meet i could and raise it back up to stock ride height without too much trouble!
Old 11-30-2009, 12:59 PM
  #56
Igor180's Avatar
Old 02-22-2010, 11:45 AM
  #57
XoDuZz's Avatar
BMW 323ci AA Stg. 1 S/C
thread revived! Whats the lowest I can go on these renntech or the C-tronic? I wanna tuck atleast half the tire in the front for show purpose. Let me know you guys!
Old 02-22-2010, 02:06 PM
  #58
beauphus's Avatar
CLS55 & CL CK60
mine claims to drop 2"
Old 02-22-2010, 04:05 PM
  #59
dacls63amg's Avatar
2008 CLS63 AMG
How much is the carlsson lowering mod?
Old 02-22-2010, 09:08 PM
  #60
polar240's Avatar
2003 C240
Earlier in this thread, someone who had links and then ELM comments on the difference in ride comfort. If this is true, the extra coin for the ELM might be worth it.
Old 02-23-2010, 12:10 AM
  #61
dacls63amg's Avatar
2008 CLS63 AMG
I think it will be worth the extra $$$.
Old 02-23-2010, 07:35 PM
  #62
RRnelcheeze's Avatar
CLS55
damn, this is an old thread, I dont even think the OP is on this forum anymore... hehe.
anyways, What about those who lowered via STAR?
if you lower via STAR, when you hit the Raise button, does it go back to stock height?
Do the different sport modes have different heights like the ELM's?
When driving on the hwy does the car still lower?
Old 04-08-2011, 09:33 PM
  #63
Former Vendor of MBWorld
Kennedy_Performance's Avatar
S63
Anyone who may have questions pertaining to the C-Tronic Lowering Module, I am now a member on MB World and am the exclusive online dealer for Carlsson North America.
Kennedy Performance Racing
954-531-5544
Old 04-09-2011, 09:34 AM
  #64
badm's Avatar
2019 E 450 4 matic wagon, cadilliac CTS AWD performance ,2018 VW Tiguan SUV 2006 CLS55 030pkg modded
C-tronic
I went with the c-tronic , put in myself no-problems , It will slam the car as low as u want to go , Remember sport 1 & 2 lower the car too . Plug & play no cutting into the wiring harness . It also doesn't really raise the suspension when driving it just compensates for the road conditions like the airmatic is suppose. purchased from Kennedy Performance , their great with tech help .
Badm
Old 09-24-2012, 03:18 AM
  #65
ydlee's Avatar
06 CLS500, 07 GL450
954-531-5544
I installed the c tronic model#31001001 for an 06 cls500 w219 as directed in the manual with lowest setting 30mm front and 25mm rear. Everything appears to be working great but I noticed when I turn engine off the car raises back to stock height. When I turn on ignition car lowers to set height it is suppose to. I thought when car is turned off it is suppose to sit low at all times? Sometimes the car will stay in low height when car engine off and parked. Is this normal? Is this an older model and the newer ones sit low when engine shut off? I have the pins open/on up for 30mm front/25mm rear as directed and for car type cls united states pin 9 closed/off down and pins 10-12 open/on up. And I have pins 7 and 8 closed off. Please any advice greatly appreciated.
Old 07-25-2013, 03:39 AM
  #66
AMGroach's Avatar
2006 CLS55 AMG
I just picked up the C tronic for my cls 55 AMG and it doesn't look plug and play to me. I got all sorts of wires that need to be plugged here and there. I'm obviously missing the white bridge connector that makes this a plug and play. Anyone know where can I get the bridge connector that makes this a simple install. The reason I purchased the carlsson is because I wanted to pop it in and go. I'll try Kennedy Performance above in the morning but if I can't get the bridge, this unit will be sitting in my closet for the next decade! Any help would be greatly appreciated.
Old 07-28-2013, 01:57 AM
  #67
AMGroach's Avatar
2006 CLS55 AMG
Wow. This forum is dead. Haha
Quick Reply: Ready to purchase Carlsson C-Tronic
