question about power mods on CLS55
Basically what I want to know is when modifying should I use all the same vendor (i.e. Kleemann, Renntech, etc.) or can I mix and match? I am especially curious when it comes to the ECU. Seems like each vendors tune would be geared toward their specs (intake, headers, etc.) but I may be mistaken.
I also would like to know your feedback on what order I should do the mods in. Here is the schedule I was considering:
1. 180mm Pulley, intercooler upgrade, ecu
2. Headers (or should I do headers at the same time as pulley and then do the ECU?)
3. Throttle body upgrade
Any other MUST HAVE performance mods? The ones above seem to be the most common but perhaps I am missing something. I already got the wheels and the ELM.
Thanks for your help!!
I think you're right on track in terms of mods, do the pulley and ecu, then you can wait on the headers. I personally like to do the mods one at a time so I can notice the difference with each mod, and see if it added power or not. After headers, pulley, and ecu, you should be happy with the performance and wont need much else, unless you wanna get up in the 700~800 hp range...
