Carbonio/VRP carbon fiber intake air box and engine cover.
It was much cheaper than what VRP was charging.
Can any one confirm if they have changed it to fit the bigger tb's or it is actuly bigger then 80mm?
In order to have it at 82mm you would have to grind out the opening but it might affect the structural integrity and obviously the warranty so I would advise against it.
I am not positive about the power gain. I need to dig around and see if we have some dyno sheets for those intakes. it comes standard with $74mm throttle body opening. the adapter will increase it to 80mm but not to 82mm
If you could post those dyno sheets! That would be great!
I’ve read a lot about the Carbonio intakes, but have yet to see any proof that they work.
The intake does look good.
What kind of deal can you give us?
