Hydro-locked engine update. Any suggestions?
CLS55 & CL CK60
Basically I now am the proud owner of a AMG that needs a rebuilt engine due to the hydro-locking I went through. Insurance company paid off the lien and handed me a check for the difference so now I get to bring this baby back to life. I am fortunate to have Hartmut Feyhl and Renn-tech corporate offices right down the street from my house. They will be doing the rebuild and any modifications I choose to do.
So basically I have a Kompressor motor with 30k miles on it that I get to modify once disassembled. What do you guys recommend? Hartmut has mentioned replacing internals with SLR pistons and rods amongst other things. I am not a tuner so I dont know much about what can be done to our engines. I am familiar with the bolt-ons and I already have those mods planned but I dont know what to do with the engine itself. What do you guys suggest?
If its been hydro-locked,it could be junk. Find someone that is EXPERIENCED with the specific motor and go from there. There is absolutely no way to tell what was destroyed. In reality, even the block could be damaged beyond repair. I'd be more concerned about getting a RUNNING engine together-than trying to decide to build a killer performance engine.
CLS55
CLS55 & CL CK60
Hydrolocked with bent rods?
If it were me (and I've rebuilt several engines) at a minimum it would get rings, rod and main bearings, timing chain with guides, and a valve job. That's the absolute bare minimum. If you've never rebuilt an engine, here's why – If a rod is bent, the crank has to be mic'd (examined to ensure it's straight). When the crank is reinstalled, no one in their right mind is going to reuse bearings or rings. Besides, any cylinder with a bent rod has bad rings. Chains and guides are cheap. While it's apart, valve jobs are cheap, so that's a given (which means it's getting cam bearings too).
If you're doing pistons and rods, you're doing a full rebuild.
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Renntech Rebuild
I'm Sure Renntech is going to install the proper rebuild parts. The SLR pistons & Rods are expensive, and they are much more durable . But understand taking your car for a boat ride
. something has got to give !! Your damn lucky it was not Salt water
. Well anyway they got to take the heads off. and touch up the valve seats & Valve faces. You might as well have the heads ported & some titanium spring retainers installed . I mean what the heck! this is a great time to get the hard stuff done, while the motor is a part! Cheers _PT Engineering
P/S I was up to MB of Ft. Pierce that had 4 customer cars that went boating Just like you. so don't feel to bad . you ain't the only one
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Former Vendor of MBWorld
C55,SL55,C63
Honestly, I think SLR pistons and rods are worth it. If I was building a motor I would do SLR internals. It would be nice to see what the weight difference is from stock vs SLR. Infact I bet I can find that out for you. From my Renntech source.
06 CLS55 AMG
Last but not least, find out about the shops or rebuilders warranty and or guarantee on his work. DO NOT, and I can't stress that enough, DO NOT work with anyone that does stand behind what they build!
Merc CLS500 & BMW X3
As for mods--be sure and ask yourself this question--how much bang am I going to get for my buck ??? I can't see spending an extra 10K on internal mods to pick up .25 sec. in the quarter mile. This is already a highly developed engine in the AMG stock form; what is further modification going to do for reliability ???
CLS55 plus a few Ducati's
MarcusF is correct and I agree with him entirely.
One thought that did occur to me concerned the effects of a mass of cold water entering the hot head and block. I would probably want them dye penetrant or x ray tested for cracks. The thermal shock would have been considerable. Good luck...
probably a good idea to balance the crank as well.
