Getting new brakes!!!
Old Jan 21, 2010 | 11:27 PM
dacls63amg's Avatar
2008 CLS63 AMG
So i ordered new front brakes. Rotors and pads. But before I pay is it really necessary to replace the rotors and pads or can I just change the pads. My rotors still have enough thickness and no cracking is going on either.
Old Jan 21, 2010 | 11:35 PM
bruin420's Avatar
CLS55 AMG
I changed mine at 48k and did only pads as they were still thick and no cracking. Did you do oem pads? Telling you Akebono is the way to go on pads
Old Jan 21, 2010 | 11:44 PM
dacls63amg's Avatar
2008 CLS63 AMG
Ya the stock oem pads. I'm not sure of the brand of pads. The dealership was so pushy on me getting the rotors also but I might just do the pads. I mean c mon only 36k miles and new rotors?
Old Jan 21, 2010 | 11:49 PM
dacls63amg's Avatar
2008 CLS63 AMG
You still have the regualr rotors that the car came with right? You only just changed the pads correct?
Old Jan 22, 2010 | 01:32 AM
bruin420's Avatar
CLS55 AMG
yup...still original rotors. If I were you I would return both and order a set of Akebono ceramic pads for the fronts which will run you about $160 for the set and then around $75 for install at an independent shop. You will be so happy with them...no squealing and no dust either.
Old Jan 24, 2010 | 05:46 PM
dacls63amg's Avatar
2008 CLS63 AMG
So should I be ok just replacing the pads and not the rotors. Only have 36k on my car. When will be a recomended time to change out the rotors also? Also where can I find these brake pads?
Old Jan 25, 2010 | 12:23 AM
bruin420's Avatar
CLS55 AMG
If the rotors have any cracks on them they need to be changed. Also when getting the brake job, they can measure the thickness of the rotors and as long as they are above the minimum thickness they are good to go.
You can buy the akebono pads on amazon and many other places. Just go to akebono.com and type in your car info so they will give you the pad info (model #) and then search for it on google. It will probably by EURxxx as the model number and will be about $150 for the fronts.
Old Jan 25, 2010 | 12:34 AM
dacls63amg's Avatar
2008 CLS63 AMG
Are these the correct pads?
http://www.partsgeek.com/catalog/200...e_pad_set.html
Old Jan 26, 2010 | 06:26 PM
dacls63amg's Avatar
2008 CLS63 AMG
Just ordered new pads and they will be in tomorrow. Il let you know how everything goes!
Old Jan 26, 2010 | 09:28 PM
LADY_AMG's Avatar
E63 AMG & CLK350
I keep hearing about Akebono's, but I swear by Porterfield R4S pads. They have virtually no dust, they have great bite and they last a while. Porterfield has to custom make the pad for our car, but they are totally worth the money.
Ps. Porterfield's are also recommended to use in High Performance Brembo kits, and since our stock brakes are OEM Brembos, it makes sense.
Old Jan 27, 2010 | 12:26 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
are the porterfields quiet as well?
might have to try them in the future but for now im very happy with the akebonos with evosport rotors. they are quiet and pretty much dustless.
Old Jan 27, 2010 | 12:30 AM
B on my Benz's Avatar
E.FIDDY.FIVE AMG
how much do these run around and if so can you send the link??
thanks
Old Jan 27, 2010 | 12:27 PM
LADY_AMG's Avatar
E63 AMG & CLK350
They are quiet, no issues so far with them.
thanks
They were a little over $100 or so for a set, not too bad. Their website is www.porterfield-brakes.com, but your best bet is to call them directly and ask for Tim, he's the manager. Their # is 800-537-6842.
