HELP! YELLOW LIQUID LEAK
Old Mar 2, 2010 | 07:44 AM
kip's Avatar
kip
E55
Hi!
Yesterday I find to my horror yellow liquid under the 2005 CLS 55 AMG (see picture).
It is located on right (the opposite side from the steering wheel) closer to the windshield. The car is working fine and no error codes. The car was standing for 2 weeks, so it is a slow leak. Any ideas what is leaking? Is it break fluid? I hate when this happens...
Thanks in advance for any help!
Old Mar 5, 2010 | 10:54 AM
kip's Avatar
kip
E55
Anyone????
Old Mar 5, 2010 | 11:17 AM
HouTxCLS55's Avatar
06 CLS55 AMG & 08 CL65 Mystic White
I had something like that happen a couple months ago. It was a combination of Oil and transmission fluid. It was about $1000 bucks to fix when it was all said and done.
Old Mar 5, 2010 | 11:20 AM
JustPete's Avatar
CLS55 AMG 030
Have you tried to feel it/smell it? Did you get down on your hands and knees and actually verify it's dripping from your car and not that you simple parked over it? Is it greasy? Does it smell like acid? Antifreeze? Oil?
Old Mar 5, 2010 | 11:31 AM
kip's Avatar
kip
E55
What did they fix?
Old Mar 5, 2010 | 11:41 AM
kip's Avatar
kip
E55
It isnt oily, its clear yellow substance. Smell is hard to tell, it was in the snow. At the moment am checking if its still leaking by putting white paper under the car. Will see. Any ideas are appreciated.
Old Mar 5, 2010 | 01:38 PM
Dericious's Avatar
CLS63
maybe a rabbit or cat was living under you car for awhile.
Old Mar 5, 2010 | 07:11 PM
Ridege55's Avatar
2011 SL550, 2007 CLS63, 2004 X5
I noticed the same thing under my car, but I have a CLS63. Just a few drops, but it seems to be coming from the same area. No error codes for me, but I will be taking it in soon for service. I'll let you know what they say.
Old Mar 5, 2010 | 08:45 PM
RRnelcheeze's Avatar
CLS55
beware of yellow snow! Sorry i had to say it!
Old Mar 6, 2010 | 03:50 AM
kip's Avatar
kip
E55
Thanks for all the input! Will keep you informed on the subject.
Old Mar 7, 2010 | 08:12 PM
Esleeper's Avatar
CLS
Serious.
I noticed a yellow puddle under one of my cars once in my garage one morning and after freaking out realized it was cat ****.
Keep us informed.
Old Mar 23, 2010 | 06:44 AM
kip's Avatar
kip
E55
So the car came out of the shop and they found.....
NOTHING, as usual. Well so far the most suspicious object is some kind of animal....
Old Mar 24, 2010 | 01:19 AM
Esleeper's Avatar
CLS
That sucks. Sometimes you WANT to find something wrong. From that day foward, every evening when I close the garage I think I'm going to close another cat inside again.
Old May 26, 2015 | 06:22 PM
craiger13's Avatar
2018 E400 Coupe
Sorry if Im a little late but I washed my car yesterday and I moved it a day later and there was a yellowish liquid under my car. I remember that the last time that I saw it was the last time I washed it same 4 inch width I chalked it up as the only time I see it is when I wash my car. but I opened the hood and saw splash from the water on the passenger side. same as before. but WHAT IS THE YELLOW FLUID THAT I KEEP GETTING RUN OFF FROM?
Old May 26, 2015 | 07:07 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
I guess the logical answer to the essence of this question is to put the car up on a lift and check it out! It ain't brain surgery, get under the car and look for a wet area. Codes don't show up until something is wrong meaning right now everything is fine but something is LEAKING!
Old Jun 8, 2015 | 05:18 PM
craiger13's Avatar
2018 E400 Coupe
Had it put up on a lift and the area was leaking due to something that was not tight and its tight now no leaks and car runs great/
