2007 CLS63 AMG
Old Feb 14, 2011 | 09:25 PM
razirafi's Avatar
2007 CLS63 AMG
2007 CLS63 AMG
A good day to all. I was wondering if anyone has a tutorial or a techical manual on how to remove the instrument cluster for this model. Any links will also do just fine.
Old Feb 18, 2011 | 10:00 AM
j21importer's Avatar
07 E63, 04 discovery
put the steering wheel in the lowest and furthest out position. the cover for the cluster pulls out gently as it is clipped into place. pull out gently at the bottom then unclip the top. once the cover is removed there is four bolts holing the cluster in place. when the bolts are completely loose they still in the cluster, remove the cluster to gain access to the electrical connector then remove.
Old Feb 19, 2011 | 03:26 AM
razirafi's Avatar
2007 CLS63 AMG
Thank you for your reply. Well, what I and a helper did was do what you just described, but since I needed also to take out the key cylinder, we eventually took out the dash trims and center console. The process was very slow as we needed to make sure nothing will be broken. It was really a pain, taking the better part of a whole working day to do, but the reward is that I now know how to remove these things and putting them back together will be a piece of cake . A few days from now I will be assembling it all back and I will take photos to share here. Maybe someone else needs to do what I just did and hopefully, my post will be able to serve as a rough guide.
