Quaife QDF9V installed (pics and vid)
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
My LSD is finally installed and it works great. Install took hours, but it was well worth it. Took a few pics and a video.
Wanted to share this with everyone. I am very happy with this product![drive](https://mbworld.org/forums/images/smilies/driving.gif)
http://www.youtube.com/watch?v=ssTGo...e_gdata_player
![](http://i396.photobucket.com/albums/pp43/khelawanb/AMG%20motor%20swap/5aa88819.jpg)
![](http://i396.photobucket.com/albums/pp43/khelawanb/AMG%20motor%20swap/60a24d82.jpg)
![](http://i396.photobucket.com/albums/pp43/khelawanb/AMG%20motor%20swap/6f4ff8bc.jpg)
![](http://i396.photobucket.com/albums/pp43/khelawanb/AMG%20motor%20swap/37c32082.jpg)
![](http://i396.photobucket.com/albums/pp43/khelawanb/AMG%20motor%20swap/dcf821ae.jpg)
The QUAIFE ATB differential is designed to prevent the complete loss of drive that occurs with a conventional differential when one wheel slips. Whilst requiring some torque in the slipping wheel, the QUAIFE unit is progressive in action but never locks – controlled power is transmitted to all the driving wheels. Ideally suited to high powered front wheel drive systems, QUAIFE ATB differentials are also used in rear and four wheel drive vehicles where optimum traction is required. Installation is identical to the normal differential with bearing pre-loads and pinion mesh being restored to the original manufacturers’ settings. Servicing of the unit is simple as all gear pinions are free fitting and normal final drive lubrication oils are retained.
As a direct replacement for the standard, factory ‘open’ differential, QUAIFE’s ATB Helical LSD unit can transform the performance of your car. Unlike a conventional plate-style limited slip unit, QUAIFE’s ATB Helical LSD unit relies on gears, rather than clutch plates for its operation.
That means it is*much smoother in operation, because unlike a conventional plate-style LSD, it never locks harshly with a set pre-load of wheel slip across the driven axle. Rather, it automatically biases the torque away from the spinning wheel across the axle, to a constantly varying degree and never locks.
To the driver (especially of a front-wheel drive car) the results are significant performance improvements;- superior, controllable traction without the harsh steering wheel ****** or torque steer that have long been associated with performance differentials. These traction benefits can also be utilised in rear wheel drive vehicles, while QUAIFE ATB Helical LSD units offer significant traction advantages fitted to the front of four wheel drive cars.
Reliability is total; the ATB Helical LSD units are designed using the latest CAD techniques and are CNC machined to ultra-tight tolerances from the very best CORUS steel billets. The completed units are then subject to rigorous in-house inspection on a tri-coordinate measuring machine before being dispatched to the customer.
Such quality means that unlike a conventional plate-style LSD the QUAIFE ATB Helical LSD unit requires no special maintenance or rebuilds, long lasting and it retains the standard method of lubrication, making for an easy, pain-free upgrade.
Proven in rallying, racing and on the road, the ATB Helical LSD differential offers safe, reliable,winning performance– everything you would expect from a QUAIFE product.
have fun, Brent ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
so, from the description
means that when just one wheel is contacting the tarmac, the car will not move.
unfortunately, this is the biggest limit it still carries, like any other traditional Lsd's
After installing the new motor the rear end in my car would sway to the right after stomping on the pedal. Now, traction is easily achieved with both wheels gripping and putting down power to the ground. Much better take off now.
I almost hit a car that was next to me once while taking off from a red light in traffic. The rear end shifted over and I had to let off the throttle and ease into it. To much time lost there. I love this mod
@DYNO "
I thought that it would be the opposite being that it gives power to the wheel that is not spinning.
2003 porsche 996 turbo
any shimming needed? im waiting for a wavetrac to be built for the slk32 and thought about a self install. my worry is gear whine and the ability to shim if needed
... nonetheless, love that behaviour
I think the summary specs reported by Brent is official from quaife ..
so, its true that power is tranferred to the non-spinning wheel
BUT for that effect to take place it requires a minimum of contact (or Torque) from the spinning wheel to couple with the non-spinning wheel. if zero contact, then zero torque and hence, zero power transfer. (this is obviously not the case when spinning on dry or even wet asphalt).
its just the way these so called "torque driven" Lsd work, in contrast for example, to "speed driven" (or Viscous) Lsd where the necessary initial input torque is provided by mean of the pressure being built by a fluid medium, as an effect of the spinning movement. .. but they also have other kinds of cons.
some time ago i found a patent (by M. Peralta, US 6402656) for an Lsd differential with a design very similar to the Quaife one, with all those meshing "worm" gears, except that it allowed for coupling of the non-spinning wheel even under zero torque condition. .. maybe it was too complicate/expensive because I've never found anything like that in practice.
or, maybe, because the combination of electronics and mechanics opened up a rally new frontier : just think at Ferrari's E-Diff ...
but, just consider that "pressure build up" tipical of viscous differentials is something different and much higher, that can be achieved only by using a specific type of meshing gears who build a positive pressure working like an hydraulic pump .. something like ... our "screw" supercharger
further they are filled with a specific high-density oil (afaik, with a high content of silicone) ... who causes power loss and, whats worst, it degradates with use (4WD vehicles fitted with a central diff of that type tend to show a 2WD behaviour when they have a lot of miles on them ...)
this is just theory .. we should ask Khelawanb to try testing (my Quaife was taking dust and i sold it a pair of weeks ago) .. putting the back of his car in a position where one driving wheel is completely lifted form ground and see what happens .... (***)
.. Brent, should you find yourself in trouble, don't worry, just call/pm me and I'll tell you a trick that should help exiting from there ..
(***) edit ... you Roverron could also try that .. maybe our electronic is already set to help in that case, even with just the stock diff !
Hmmm. I will need to plan this little test when I get back from your country Dyno. Ive seen one CDI CLS so far. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I also was wondering if and to what extent our electronics can proactively work with the differnetial ..
.. Brent, should you find yourself in trouble, don't worry, just call/pm me and I'll tell you a trick that should help exiting from there ..![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
usually they are no label when not amg badged
that's what happen when 2.3 $ is not enough for 1 liter gas
what are you waitin uploading a few nice pics ...
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
![](http://i396.photobucket.com/albums/pp43/khelawanb/greece%20and%20Rome/ebada770.jpg)
Your country is beautiful. Can't believe I'm standing where gladiators fought.
