How to wire fog lights to always be on?
Old Aug 27, 2011 | 12:43 PM
curtisG's Avatar
2009 CLS63 AMG + 2003.5 M3 e46
I'm converting my fog lights to LEDs to act as DRL's on my 2009 CLS63.
Can anyone give instructions on how to rewire them so that they automatically come on when the car is started without having to manually turn them on with the fog light switch?
TIA
Old Aug 29, 2011 | 12:45 PM
xpl0sive's Avatar
CLS55 AMG
i want to do this as well... i thought there was a way to do it with STAR but i'm not sure...
Old Aug 29, 2011 | 01:30 PM
Elrajel's Avatar
CLS 55 AMG (Fully branded CLS 63 AMG / Special Color Ferrari Grigio Titanio)
Simple question: do you use headlight always turned on when starting your car (option available in computer menu) ?
This is what I'm doing and I linked my LED with city light wires so very easy to get LED in addition with headlight
If you plan to use LED light only, the solution would be to get power directly from your alternator (dynamo)
Hope it helps
Old Sep 5, 2011 | 09:29 AM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
Hope it helps
Yes, this is correct. You can wire the positive wire directly to the back of the alternator. Lights will come on as soon as you start the car. Once this is done you will get a pesky message about your fog lights every time you turn on your headlights. Small price to pay for a sweet look
Old Sep 6, 2011 | 04:49 AM
Elrajel's Avatar
I don't use that scenario (from alternator) so I cannot confirm for the pesky message on the dashboard...
But I confirm using the LED connected to city lights and lights turned on as of ignition on (option exisits on menu) has no impact and display no dashboard message
Old Sep 6, 2011 | 10:45 AM
khelawanb's Avatar
Cool! So feeding wire to the city light wiring has no impact or voltage issues?
Old Sep 6, 2011 | 10:49 AM
clkwork's Avatar
CLK63 Black Series
I would use one of the city lights to flip a relay, then run a new, fused line to the battery or high current source to drive both sides.
Old Sep 6, 2011 | 01:08 PM
Elrajel's Avatar
Yep ! You can give it a try and check by yourself.
It's very easy and quick to wire and check before definitely leading the wires to the front bumper.
I'm based in Europe (France) but don't see any reason why it shouldn't be the same for you guys overseas
BTW, this is LED and very low consumption.
