CLS W219 facelift LED Tail lights modules
Rating: Thread Rating: 3 votes, 4.33 average.
Old Jun 9, 2024 | 04:10 PM
  #601
Nsbkeys's Avatar
Sl 129 cls
Module cls
Originally Posted by TheFrenchy
Thank you for your message, i will tell you tomorrow what happened.
Regards,
Frenchy.
salut, je te contacte du 54.
as tu 1 kit module feux arriere phase 2?
mon adresse mail: nsbkeys@gmail.com
Old Jun 9, 2024 | 07:41 PM
  #602
sonoplay219's Avatar
w219
Modulos
Hola Frenchy,me gustaria comprar un par de modulos “facelift Led Tail Lights”
producciones@sonoplay.es
Old Jun 10, 2024 | 08:49 PM
  #603
R1boy's Avatar
2008 cls550
W219 tail lights
I’m interested in purchasing a set of modules
Old Jun 10, 2024 | 10:39 PM
  #604
R1boy's Avatar
2008 cls550
Originally Posted by 5280CLS55
Ballast and lights ready to ship!
$1,300 + S&H
Attachment 376189
do you have anymore of the taillight upgrade kits
Old Jul 6, 2024 | 09:32 PM
  #605
hpt1975's Avatar
2007 CLS 320 cdi
Price for this module shipped to UK
Hello,
As promised on anoter thread, i'm happy to
Show you the video of the first Plug & Play module,
that allows you to swap your old Tail lights for the
LED Tail lights from the 2009+ facelift model.
Every lights work perfectly without generating any error on
Your Instrument Cluster.
To upgrade your tail lights, you'll have to remove the plastic traverse in the trunk to Access all bolts, and bend a little bit side carpets.
Then, unscrew the 5 bolts of the Tail light, swap it with the new one, fix it with the 5 bolts, plug the module on your OEM connector (harness of the car), without cutting anything, and plug the other connector (from the module) to your new Tail light. Then you'll just have to attach the module on the traverse bar above the rear SAM, and that's it !
http://www.youtube.com/watch?v=pzZyJ...e_gdata_player
As you will see on the video, the sample is not completely finished, need to drill a hole In the box to run wires Safely out of it.
Everything will be ok on the finished product.
Regards,
Frenchy.
please could you email me a price for these. Shipped to UK. hpttranter@googlemail.com
thank you
Old Aug 19, 2024 | 01:37 PM
  #606
jcord500's Avatar
w220 s500
Hi @TheFrenchy If you're still making them, would I be able to order a set of modules. Wasn't sure if they get hot enough to warrant it, but do you sell them with some additional heat sinks or cooling? My email is jcvollmuth@gmail.com, they would be getting shipped to Charleston South Carolina in the US. Thanks!
Old Aug 31, 2024 | 06:00 PM
  #607
737's Avatar
737
2013 S550 4MATIC, 2011 S550, 2010 S550, 2008 S550, 2007 S550, 2010 CLS 550, 2008 CLS 63 AMG
W219 tail light upgrade module
Hello Perry,
check your junk mail, I’ve sent you a mail on 16th july.
Cheers,
Frenchy.
Good Afternoon. I'm interested in purchasing a tail light module to upgrade the taillights on my 2008 CLS 63 AMG. If you could get back to me at your convenience, it would be appreciated. Thank You & Have a Good 1!
Old Aug 31, 2024 | 06:05 PM
  #608
737's Avatar
737
W219 Tail Light Upgrafe Module
Extremely Interested in purchasing module.
please contact me at:
snmnlaverty@proton.me
thank You!
Old Sep 6, 2024 | 06:27 PM
  #609
alwaleed's Avatar
cls 500
Interested in purchasing taillight units
Hello brother, for a year I have been trying to contact you to buy. I have already bought the taillights, but I am waiting for the converter. Please do not forget me. I am in the Middle East. Thank you...
my email: altintop2011@gmail.com
Old Oct 4, 2024 | 04:43 PM
  #610
Emilio198043's Avatar
Saludos frenchy necesito esos módulos para envío a puerto rico!
[QUOTE=TheFrenchy;4980849]Hola,
Como prometí en otro hilo, me complace
mostrarles el video del primer módulo Plug & Play,
que les permite cambiar sus viejas luces traseras por las
luces traseras LED del modelo facelift 2009+.
Todas las luces funcionan perfectamente sin generar ningún error en
su panel de instrumentos.
Para actualizar sus luces traseras, tendrá que quitar la barra transversal de plástico en el maletero para acceder a todos los pernos y doblar un poco las alfombras laterales.
Luego, desatornille los 5 pernos de la luz trasera, cámbiela por la nueva, fíjela con los 5 pernos, conecte el módulo en su conector OEM (arnés del automóvil), sin cortar nada , y conecte el otro conector (del módulo) a su nueva luz trasera. Luego, solo tendrá que colocar el módulo en la barra transversal sobre el SAM trasero, ¡y listo!
Como verás en el video, la muestra no está completamente terminada, necesitas perforar un agujero en la caja para pasar los cables de manera segura.
Todo estará bien en el producto terminado.
Saludos,
Frenchy.[/QUOTE
Old Oct 6, 2024 | 08:26 AM
  #611
EK74's Avatar
Hello Frenchy,
I am interested for the tail lights module.
my email: eliaskhalafo56@gmail.com
thanks
Old Oct 31, 2024 | 01:06 PM
  #612
ICARS's Avatar
Mercedes CLS 63 AMG
Frenchy I need the module as well
Hello Frenchy,
I need the module set as well. Could you contact me please: info@icarsautobedrijf.nl
Old Nov 2, 2024 | 04:25 AM
  #613
ICARS's Avatar
Mercedes CLS 63 AMG
Hello Frenchy,
I need the module set as well. I got the lights already. Could you contact me please: info@icarsautobedrijf.nl @TheFrenchy
Old Nov 7, 2024 | 11:50 AM
  #614
Sean010's Avatar
@TheFrenchy
are you still doing the modules please,
cheers
email is….
sean.bishop@live.co.uk
Old Nov 16, 2024 | 06:54 PM
  #615
TheFrenchy's Avatar
Hello Mercedes fans
I have been told by a member that he has been scammed by a guy from France telling he is « Frenchy » 😡😡
i have his datas and will declare his bad business to the authorities.
Please take care and don’t put your mail in the topic, you’d better send me a PM.
Tomorrow I will take a moment to answer to all of you.
Thank you all,
‘Cheers,
Frenchy
The photo he is using. As you can see, those modules are not mine.
Old Nov 17, 2024 | 11:46 AM
  #616
Sean010's Avatar
Thank you very much Frenchy
Old Nov 21, 2024 | 11:40 AM
  #617
Socha.C219's Avatar
Conversion modules
@TheFrenchy hey brother I got some OEM facelift tail lights and would like to purchase those modules, how could I go about ordering them.
Thank you!
Old Nov 28, 2024 | 07:41 AM
  #618
Tiago's Avatar
CLS 350
Hello Mercedes fans
Thank you all,
‘Cheers,
Frenchy
Hi Frenchy.
Thank you so much for the reply.
From the beginning i felt wrong posting the email into a public forum and sent you already two PM for the deal and giving my personal email.
I know that this is a hobby for you so when you have some free time, please give me a reply.
All the best.
Old Nov 28, 2024 | 08:02 AM
  #619
Tiago's Avatar
CLS 350
Hello Mercedes fans
Thank you all,
‘Cheers,
Frenchy
Hi Frenchy.
All the best.
Old Dec 3, 2024 | 04:37 PM
  #620
Sean010's Avatar
@TheFrenchy ,
any news yet on the modules
thanks
Old Dec 7, 2024 | 05:22 PM
  #621
Cls219james's Avatar
Want to buy some modules!!
Hello @TheFrenchy I would love to purchase a set of these modules. My email is jamessocha@live.com. I look forward to hearing from you!!
Thank you!!
Old Jan 17, 2025 | 07:28 AM
  #622
Ron3008's Avatar
Hi @TheFrenchy
do you still produce these modules? Unfortunately I cannot send you a private message yet It would be nice if you could send me a message for details.
Many thanks and greetings from Germany!
Old Jan 20, 2025 | 09:05 AM
  #623
Thekarlbenz's Avatar
Module pour feux led CLS
Bonjour @TheFrenchy , je voudrais savoir si vous pouviez me fournir les fameux modules pour feux arrières Led pour la CLS .
Je vous laisse me contacter sur mon e-mail
mh25300@hotmail.fr
Merci.
Old Jan 21, 2025 | 08:28 AM
  #624
Cls55amg@Tan's Avatar
Cls 55 amg
Hello,
I wish to all a Happy New Year.
I've already sent a PM to 20 members, i've got an answer from half.
Please Check your Inbox.
For those that didn't have PM, please contact me if you're interested.
I'll give you more details.
On Saturday, i'll meet the Tech' and will post some pics of the final product, with some minor modifications (boxes, "IN" plug) etc...
I will also post the DIY for removing Old Tail lights and fitting the facelift ones.
Regards,
Frenchy.
Hay Frenchy do you have any of the face-lift taillights adapters for a mercedes cls 219
I want to install the facelift lights,and the price please
Old Jan 21, 2025 | 08:31 AM
  #625
Cls 55 amg
Hello Frenchy,
my email: memie1909@gmail.com
Its for a europa model
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
