CLS W219 facelift LED Tail lights modules
#203
Led tail module cls w219
I would like to buy THE rear light module for cls led lights from you please. THE Price you ask for this is how much? Shipping to belgium possible? In need them very fast please. Greetings kris.
#206
A heavy 63
Hey fellas I have a set of ballast that I would like to sell also. I bought them from another member name khelawanb. I can't use them anymore because my car was totaled so they are still stilling is the same box that I picked them up in, which is the same box that it came when Frenchy sent them. I am located in NYC if anyone might be interested in picking them up personally.
#208
Hello,
As promised on anoter thread, i'm happy to
Show you the video of the first Plug & Play module,
that allows you to swap your old Tail lights for the
LED Tail lights from the 2009+ facelift model.
Every lights work perfectly without generating any error on
Your Instrument Cluster.
To upgrade your tail lights, you'll have to remove the plastic traverse in the trunk to Access all bolts, and bend a little bit side carpets.
Then, unscrew the 5 bolts of the Tail light, swap it with the new one, fix it with the 5 bolts, plug the module on your OEM connector (harness of the car), without cutting anything, and plug the other connector (from the module) to your new Tail light. Then you'll just have to attach the module on the traverse bar above the rear SAM, and that's it !
http://www.youtube.com/watch?v=pzZyJ...e_gdata_player
As you will see on the video, the sample is not completely finished, need to drill a hole In the box to run wires Safely out of it.
Everything will be ok on the finished product.
Regards,
Frenchy.
Regards,
Frenchy.
I am looking for a module CLS W219 facelift LED Tail lights modules for Mercedes cls 320 CDI 2006 how can we procured them please, I'm French Marseille, and can you give me the price and coordinated ordered?
Regards Alain.
in French:
Bonjour,
je suis a la recherche d'un module CLS W219 facelift LED Tail lights modules pour Mercedes cls 320 CDI 2006 comment peut-on se les procurés please , je suis français de Marseille , et pouvez vous me donné le prix et les coordonné pour commandé ?
Cordialement Alain.
#210
Hello there,
Regards Alain.
in French:
Bonjour,
Cordialement Alain.
Regards Alain.
in French:
Bonjour,
Cordialement Alain.
#212
Hello,
Happy new Year to every member.
After many many many mails and PM about the modules,
I've decided to produce a new batch.
Let me first buy all parts needed, i will let you know when orders can be placed.
Best Regards,
Frenchy.
Best Regards,
Frenchy.
#213
Mark
#215
#218
Hello Frenchy,
I have a S204 of 2009 would like to tell me the price of the module and if you could send the modules to Portugal.
My email is prcarrilholx@gmail.com.
Best regards
Best regards
#219
Hello frenchy,
Are you still making those modules,,if so, I want to buy a set
Alkhalifah-a@hotmail.com
#221
Hello Friends,
I'm back !
Stay tuned, i will post good news very soon, i still busy and working hard for the next 3 weeks, but don't worry
Regards,
Frenchy.
I'm back !
Regards,
Frenchy.
#224
I ended up buying the Pogea racing modules and new rear lights from Merc. Strangely I have 4 LEDs which don't light on either side in the same position. It doesn't look bad as its right at the end of the light so looks like its how it should be but quite annoying.
Merc will look at the lights but will charge 1hour labour if they find its not a problem with the lights. The pogea racing boxes were hard enough as it is to get from Germany so that will be a pain to check with them so might have to live with it.
Either way it still looks a million times better than the old lights. Expensive but highly recommended.
