well... my cls is getting fast !!!!!
2006 cls 55 amg
i did not dyno it..but i assume around 480 to the wheels, and yes 105 oct tune,,,and cat delete...that's it that's all !!!!!
full weight --- just the spare tire removed
Former Vendor of MBWorld
I clicked off a 1.69 this past Sunday. I did it when the temp was around 50*, running 22" wheels and about 40psi all the way around lol. Ran a 11.932 @ 112mph (keep in mind DA was over 6000). Track prep is pretty good at Bandimere. It's one of the National stops so they keep it in pretty good shape. The last time I took the Benz out on several occasions it spun until half track. My times were as much a 2 sec different depending on how good I'd hook.
2006 cls 55 amg
thank's guys !!!!!
i put 22 psi in the DR...when cold...and up to 28psi when temps is hotter,,track prep is always top notch at napierville dragway ( 200 feets above sea ).... 1.721 is my best 60 ever... usually its 1.75 -- 1.76
2021 Porsche TTS
Impressive indeed. It shows you how just tires and cool temperatures can lower your time significantly.
Both tuned W218 in hot South Fl weather could not go under 11.5 in Bradenton last month.
