Couldn't shift car into gear...
Old Mar 6, 2014 | 11:11 AM
Manofsteelpt's Avatar
Veteran: Army
S63
Started my car (09 CLS63) up this am for work and I couldn't put it into reverse. The shifter moved to the right, but that was it, I couldn't pull it back to R, N or D. It appeared as if it was locked... Turned the car off and restarted and same thing. Turned it off again and restarted and all was well.
Any thoughts on this?
Old Mar 7, 2014 | 09:41 AM
Og Asr's Avatar
2008 CLS 63 amg
I have had the same thing happen...did the ESP light come on? Usually...that happens to me...but it's not all the time. I did the same thing you did...pull out the key.....and eventually the light did not come one...and I was able to shift to reverse. I'm going to take it to the dealer and mention it....only happens when you first start the car up..and the ESP light comes on.....you get locked out...and you can't shift from Park.
Old Mar 7, 2014 | 10:41 AM
1SickCLS's Avatar
CLS55 AMG
I was at the track the other day and had mine in dyno mode. I drove past the water box and went to reverse to just get my rear tires into it. Well it wouldnt go into reverse or drive after that. So I shut it down and turned it back on, and all was well like you stated.
Later I noticed a check engine light and the code said it had an incorrect gear ratio. I havent had the probelm since.
Old Mar 7, 2014 | 11:04 AM
Veteran: Army
S63
I didn't get an ESP or CEL when it happened... Very odd
Old Mar 9, 2014 | 01:02 PM
Og Asr's Avatar
2008 CLS 63 amg
Bad brake switch. should be covered under my CPO.....it also causes the ESP light to light up....
Old Mar 11, 2014 | 08:11 PM
AMGAffalterbach's Avatar
2014 BMW M235i
^+1, bad brake indicator switch. Had this happen to me and ended up being an $18 part that got me stranded, had it replaced for cheap at StarTech.
Old Mar 21, 2014 | 10:27 AM
Og Asr's Avatar
2008 CLS 63 amg
Thanks....taking the car in on Monday for CPO coverage.
Did it also mess with the parking sensors? I am getting errors when driving on the freeway......starts beeping like crazy...always have to disable the parking sensors with the button near gear shifter.
Old Mar 22, 2014 | 04:04 PM
2014 BMW M235i
I don't have parking sensors on my car so I couldn't tell you, but it did mess with SpeedTronic, ESP, and all of the associated services so I have a feeling it probably would.
