CLS55 Heat Exchanger Sale
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
What is the Additional capacity in terms of rows/tubing and surface area between stock and your unit?
2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
Can you demonstrate what the advantage is to this HE with actual numbers? Also, do you have detailed mounting instructions you'd be willing to share? Thanks in advance!
You deleted my message in your other thread so I'm not going to be as nice with this response. Can you show that your heat exchanger, which looks similar to stock, does anything except waste money? The build quality looks like a four year old welded it.
I think you should buy one put it in your car and in your words of wisdom (the same way you are explaining everything and anything to us on this forum) do the same for the cooler
Simple questions deserve simple answers. If you can't answer a basic question about the improved performance over the stock BEHR cooler for hundreds of dollars, then you're either condoning ripping people off or you're a fool.
