CLS 55 Steering Angle Sensor
Old Oct 21, 2015 | 12:32 PM
Danny Vendel's Avatar
CLS 55
Hi.
I think I need to replace my steering angle sensor. What I can read is is a common problem with the CLS 55 w219.
The problem is that I am trying to find the SKU of this part and also if it is the same part for the CLS 55 as for the CLS 350 and 500 and so on.
I also heard that it might help to just clean the sensor and put it back. Anyone had any luck with that?
Thank you.
Old Oct 22, 2015 | 03:25 AM
StuttgartAMG's Avatar
E55 AMG (W211)
There might be a problem with the slave driver (!? don't know a better word for it), if the steering angle sensor was pushed too far.
There are different angle sensors available, depending on VIN.
CLS350 or CLS500 do have the same sensor.
Old Oct 22, 2015 | 02:55 PM
CLS 55
Is it same to the CLS 55 as I have as well?
Thanks.
Old Oct 23, 2015 | 04:11 AM
E55 AMG (W211)
Depending on VIN: Maybe.
Old Oct 23, 2015 | 09:20 AM
CLS 55
This is my VIN:
WDD2193761A028722
How can I tell which one I need.
Thanks.
Old Oct 23, 2015 | 11:12 AM
AndreNY's Avatar
couple of Benzos
you need part #171 540 29 45
Old Oct 23, 2015 | 12:10 PM
CLS 55
AndreNY: Thanks alot, but when I do a search on that SKU everything sort of point me in the ditection of a Electric Steering column adjuster. Can you please have another look at this.
Tank you vert much.
Old Nov 5, 2015 | 02:01 PM
jaimejrivera's Avatar
2012 C63
I have a new steering angle sitting on a shelf. If interested I can sell it to you.
Old Nov 5, 2015 | 02:05 PM
2012 C63
Before you invest in the steering angle sensor... check the switch on the brake pedal responsible for turning on the brake lights. It is a double pole switch that when fails it trigger a warning message.
