Crashing sound on liftoff
Old Sep 8, 2016 | 09:44 AM
Fivehunnit's Avatar
CLK500 (2002)
this is pretty much how my old ford sounded when the engine mounts were shot, low gears revving up to around 6k then lifting off, I get a slight crash sound like I've hit a small pothole, is this likely the motor mounts or a suspension part? Thanks
Old Sep 9, 2016 | 10:14 PM
hvacdude's Avatar
2006 CLS55AMG & 2005 S55AMG
What you said and check the super charger bearing too.
Old Sep 9, 2016 | 10:25 PM
ItalianJoe1's Avatar
2003 CL 600
Try it stationary. Put the car in drive, hold the brakes, step down hard and let off. Try again in reverse. There should be no clunking or jumping around of the engine.
Very common for the mounts to break on these cars, not a terrible repair unless it's 4-matic, then it's very space limited.
Old Sep 10, 2016 | 08:26 PM
Fivehunnit's Avatar
CLK500 (2002)
thanks for the replies, will try that for sure (no supercharger btw)
Old Sep 16, 2016 | 10:44 AM
06cls55amg's Avatar
06cls
change motor mounts and transmission mount
Old Sep 16, 2016 | 02:44 PM
knownworldwide's Avatar
1995 E320 Wagon
It is definitely a mount. I had my engine mounts replaced at 68k they were completely destroyed. Sounded similar to what you are saying. If not that move gradually to the rear of the car first to the trans mounts the. To the diff mounts and lastly the subframe mounts. While I am fairly certain your engine mounts are shot it isn't entirely impossible that these other mounts are tired after taking some mileage.
Old Nov 2, 2016 | 10:39 PM
designzio's Avatar
21 E63 Wagon
My brother zip tied an old iphone to the under carriage to view which mounts were messed up via recorded video. Smart idea.
