Head removal on CLS63 M156 engine – FYI/DYI
The CEL Codes showed several cylinder misfire. No loss of coolant and after hunting around decided to do a compression test and all cylinders had great numbers but for cylinder 6 which didn't register. Subsequent leak down test showed number 6 at 100% leak with exhaust valves the suspect. Considering the problem happened at start up of it seems reasonable to assume an exhaust valve(s) got tagged or stuck open.
The quote for the repair was about half what the car is worth (thx MB depreciation) so the my option is trading it in with a bad engine and get pennies on the dollar or bite the bullet and potentially end up with a 5 digit bill (head bolts, valve buckets, cams, head work, or worst) and have a car that is still worth less than new Civic!!
So after some consideration I decided to pursue a third option and do a DYI. I researched the M156 engine and found a lot of information about replacing head bolts on the M156 and tappets/cam follower but couldn’t find a thread that covered pulling the heads. So I have decided to document the head removal process for future reference…and potential comedic relief especially if I fail ☺.
I have ordered a WIS off eBay and the timing toolset that just got delivered…. Actually don’t care about the WIS other than torque values… few days left in the Spring break - so going to get going right away!
NB; usual disclaimer - this is meant to be more an FYI vs a detailed step by step DYI since it does require basic mechanical skills and some of the pics may be out of sequence (LOL). I'll try to keep time that I spent for each step (excluding the online research and parts order) as a reference for what the book recommends.
Now the tedious but easy stuff, remove air intake, filters, after disconnecting the MAF. There are a couple of clips that lock the back intake hose – one is accessible on the driver side and you can wiggle the hose out. Remove the coils, spark plugs and wiring, clip the zip ties to free up the wires. Drain the steering pump reservoir, remove hoses and pull reservoir (even if you think you drained it…it will spill oil so plug the lines and set them aside with a zip tie). Remove the air control valves, (the driver side one is a little challenging) and other related parts. Whenever there two of the same (ie cam solenoids I match the connectors with yellow dots - helps with reassembly especially when projects take severals months). Remove the serpentine belt (17 mm socket, use an large nail to keep the tensioner in tension). 1-1.5 hours
Now back to my other projects
The front covers have a ground that you need to remove as well as the phasor solenoids (make sure to label the intake and exhaust)
Cams look in good shape with no abnormal wear on the lobs
with some of the valve buckets displaying uneven wear (picture taken after disassembly...obviously)
Rooting around and further investigation show one of the buckets is super easy to push down (I use a brass tool not to damage the cams).
So broken valve spring? This seems highly probable as the cause – spring breaks, valve gets tagged, and compression goes to zero… 1 hour to remove the covers, another 1 hr rooting around and deciding what to do next!
I'll have to wait till I see it in person to determine if this is all a problem or not.
Use a rag to collect fuel that will spill when removed…use that rag to wipe down the oil that spilled when you pulled the valve covers.
Disconnect back PVC hose (just replaced mine but if the car is older it will probably crumble) and vacuum line.
Disconnect intake temp sensor (I broke the clip on mine).
I recommend removing oetiker clamp for the vacuum the tube near the pass headlight since the other side is difficult to reach with manifold in situ.
Pull the intake manifold, now is a good idea to vacuum up any debris in the V before proceeding. The bolts are aluminum one time use so add the to order list.
The intake manifold looks clean despite 70k miles of mostly city driving.
Time, about 20 mins
To remove manifold from head, you will need to disconnect from down pipe – two bolts (E12 torx) – again the accessibility is surprising good from under the car.
Once those are removed, gasket comes out and the manifold can be laid on its side for better clearance (once the head is off I will put it a clean off the oil that spilled).
1hr
.. Use M4 8mm to lock the narrower gear in place - if it’s longer than that, it will bottom out and you won’t have the narrower gear secured properly (Put a rag under to avoid dropping the bolt in the block!)
Stop take a breather and get on favorite paint pen color (I like yellow), mark each cam, Exh vs Int and left or right. Do the same with the phaser and reference the front part of the phaser (notched disks) in relation to the body.. I inserted the timing tool (silver) to make sure everything was aligned. Insert the locking tools (front and back of cam) and use the cam cover bolts to secure in place.
Now the phaser bolts come off and the phaser are removed.
Mind the very thin washer btw the cams and the phaser – expect a fair amount of oil to seep out. Now the only thread on MBWorld I was able to find showed the contributor (working on a C63) pulling the cams with the phaser in place…honestly I am not sure how that works since you can’t release the cam loading prior to removing the bearing caps (not sure how the cams get put back in place – contributor doesn’t show how it was reassembled.
After removing the phasers, remove the locking tool and rotate the cams until the cams are “loose”, i.e. not loading a valve spring.
Now unbolt the caps and make sure you keep everything in order as you can’t switch them around. I take a marker and put a dot on the cam caps towards the front of the engine to make it easier to ID.
The cams look quite good, so will not need replacement, though may send out for polishing…valve buckets do show wear with over half needing replacement IMHO.
2 hrs
Tensioner access isn’t great but a 24mm socket will extension and breaker bar will get it moving. Again there will be oil…so have rag ready (bad pics).
This loosens the upper timing chain and allows the upper sprockets to be removed. You will need another timing tool part # 156-589003400 and the recommended puller which looks like $300 paperweight so I decided to pass and improvise as needed. Bolt handle is not MB part
Remove allens that hold the shaft in place and insert the socket.
Good news was that I was able to remove the shaft of the left head with just the hand puller. The right didn’t want to budge so I decided to wait and see if I really needed it to come out (the head is ok and don't plan to pull off).
On to the timing rail pins (2 per side) and both are obstructed by something, upper one required removal of the oil filter mount, which requires removal of the belt tension since one of the lower is obstructed. The lower pin requires pulling the metal hose – access is under the head and "fiddly".
Now with pins exposed you need a m4 stud to insert in the end of the pin and the magical $300 paperweight puller that I don’t have… This turns out to be my biggest headache to date. So I improvise and take my blind hole bearing puller apart to use the slider weight and a long bolt to which I weld and M4 bolt – Voila! – shady tree mechanic version of the tool.
So I spend 10-15 minutes whacking at the pin with no success. I am thinking this is going to end up in tears and the bolt or the treads in the pin are going to strip and I will be SOL. Approach version 1.5, I take another M4 and large washer and thread into the pin
Bingo – after a little nudge the pin moves
…I add washers and am able to finish pulling it with my awesome puller. On to the bottom pin where I used a similar approach. 3 hrs because of the headaches!
Pin one of two out (will replace with new one)
Now small nudge the head, expect some coolant to spill…
Success, head come off cleanly! 1 hour because I did a brief conference call.
Pistons look good with expected carbon build up...strangely no marks on the piston...maybe some good news?
My first assessment of a broken spring and bent exhaust valve is partially correct, valve looks good.
The spring is definitely broken but fortunately the valve did NOT get tagged…
so will blue the valve but since the leak down of the other cylinder is excellent, I plan a simple clean up.
Regarding the removal of the cams with the adjusters together, I have seen at least three guys who did that with no issues. Only thing is you need to remove the bridges holding the cams slowly/very carefully so the pressure will no break the cams.
TBH I don't know how they managed Installing the cams with the adjusters in place, one bloke said it was very hard and took him longer time, so he removed the adjuster on the other side when he started working on it.
Well, it looks like defective camshafts, camshaft adjusters, valve tappets(bucket) and headbolts are not enough of a headache/nightmare on the M156 we are now hearing of broke valve springs..... No wonder the M157 is based on Mercedes M278 engine, and tuned by AMG (same as the M113)
Good luck mate!
Good luck mate!
So only missing piece is the WIS!
Head gets cleaned as does the block
Time to drop the exhaust manifold back in and the metal hose the go to the air valve. Real PITA to reinstall as the bolt to secure is out of sight under the head. DO NOT tighten until the chain rail pins are in place (see below - hose is in the way of one the pins).
NB the upper chain socket is not touched or removed during the head removal process, it stays in place (prevents the chain from falling) as the head slides out, so installing the head back on is the reverse process – it’s a tight fit but easy to do with a little patience.
The revised head bolts look different and have special coating on the load bearing side.
Head bolts had a specific tightening sequence and a 5 stage loading
10NM – 50NM – 90 degrees plus 90 plus 90. I have a simple torque angle gauge for that.
The passenger side bolts get replaced, one at a time (confirmed that is was ok). I use brake cleaner to make sure everything is clean where the bolt loads up the head.
again the bolts look OK.
Now the head is in place, reinsert the chain socket shaft and tighten the M4 Allen bolt that keeps it in place and tap in the new chain rail pins till they are flush. Time to load up the chain by installing the tensioner, good time too to check that crank is still at the 40 degree mark.
