help with CLS55 build
Old Feb 20, 2018 | 12:53 AM
Brandon Beard's Avatar
2006 CLS55 AMG
I Just bought my first 06 CLS55 AMG and looking to make some power
I'm very familiar with LS but not the M113k
Where is the best place to start? seen a lot of people straight pipe and TB along with pulley and tune and some mention to loop the fuel rail because of cylinder 8
not wanting to jump any steps and I'm new to this world
Any advice would be greatly appreciated!
Old Feb 20, 2018 | 04:32 AM
PieRat's Avatar
CLS55
Hey man. First get a new Intercooler pump if hasn't already been replaced with either a bosch 010 or aftermarket upgrade. Then a tune for your ECU from jerry at eurocharged or anthony at raceiq. They're both awesome.
Get yourself some headers, mid-length are easy and generally cost effective. If you want a littlw more power from them get longtube but unless your really pushing the platform I dont think theyre neccesary. You can also cut secondaries and put om x pipe.
Second optiom varies dependant on climate if your im a hot one get a bigger heat exchanger for your supercharger. If its cooler where you can go straight onto a 77mm/76mm pulley but you WILL want to get the HE eventually if you dont want to wait a couple mins of cruising after every two back to back pulls.
Good alternative to HE is a killer chiller
At this point you could consider water/meth injection and or a trunk tank. Probably best to save risking the TB til last.
Let me know if you have any questions or need help sourcing parts for cheap as poss.
Old Feb 20, 2018 | 04:35 AM
PieRat's Avatar
CLS55
There is a bunch of other stuff you can do as preventative maintenance, let me know if u wznna hear about that..
Also after headers 1 step colder plugs are a good idea.
Old Feb 20, 2018 | 10:02 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I can help with any power mods you need as well as throwing together packages to get you some sweet discounts!
pm me if you need anything
Old Feb 20, 2018 | 09:26 PM
2006 CLS55 AMG
Anything helps man new to this world so any advice would be great
Old Feb 20, 2018 | 09:39 PM
2006 CLS55 AMG
thanks man!
Old Feb 20, 2018 | 09:44 PM
2006 CLS55 AMG
I’m currently looking at the v2 fuel system from fabtech performance http://www.fabtech-performance.com/p...v2-fuel-system to fix the cylinder 8 issue I’ve heard of.
Then next the HE kit from eurocharged https://www.eurocharged.com/products...es-cooling-kit
would you suggest this kit?
Then get the eurocharged engine tune https://www.eurocharged.com/products...ngine-software
would y’all suggest all of that and in that order? Afterwards there headers? I see eurocharged has shortys but who has long tubes? Like to have longtubes with full 3” exhaust no cats what do y’all think??
Old Feb 21, 2018 | 12:19 AM
PieRat's Avatar
CLS55
Skip the kit for later. Go tune, headers. Stock HE is OK until you you overdrive the SC in mg opinion
Old Feb 21, 2018 | 12:24 AM
PieRat's Avatar
CLS55
Actually your in texas get the HE asap. But Id look at killer chiller too, especially if your talking heavy mods in that climate. If you overdrive the SC in that climate ur looking at HE, trunk/enginebay tank and a big pump...Killer is as good if not better than that combo for drags/street. If you track it i think after a lot of abuse the ac compressor cant keep up..can't remember. DONT FORGET TO UPGRADE/REPLACE YOUR INTERCOOLER PUMP IF FACTORY ONE IS STILL IN IT.
2006 CLS55 AMG
I will be replacing the SC pulley, but after the HE correct?
is that kit okay? And what pulley would should I use I found this 77mm https://www.eurocharged.com/products...charger-pulley or what you suggest
Old Feb 21, 2018 | 12:27 AM
2006 CLS55 AMG
So killer chiller is A HE correct? So I just need that along with an inter cooler pump right?
Old Feb 21, 2018 | 01:03 AM
2006 CLS55 AMG
https://killerchiller.com/products/u...l-parallel-kit
the universal one right here right?
Old Feb 21, 2018 | 02:31 AM
PieRat's Avatar
CLS55
Yeah mate. That's the one. The killer chiller basically uses the air conditioning unit instead of the heat exchanger, so I think you'd want to ditch the HE completely if you go that path. You could run a bypass valve so you can turn the HE on/off if you wanted, not sure if you have to run AC all the time with the killer chiller. You need to do the cooling mods before or at least when you put in the 77mm, the one you linked is a good one. For the headers, if you take out the secondaries and put in an x-pipe, the mid-length by eurocharged lose only 4-10hp and are less than half the price of cheap long-tubes..Best to put that money toward other mods.
Are you going to be putting all this in yourself? If your looking for a shop to do it, talk to Longun you should be able to get the sh *t installed at one of the eurocharged locations and they'll do it proper. If your mechanically minded you'll find DIY's for all the mods..
Old Feb 21, 2018 | 02:43 AM
2006 CLS55 AMG
i will be doing it myself, i actually own A mechanic shop in Longview, but iv never worked on a m113k and I know every vehicle has its flaws and weaknesses so I’m just trying to make sure I do this car right and not skip anything
Old Feb 21, 2018 | 02:44 AM
PieRat's Avatar
CLS55
Maintenance mods (keep engine running pristine, these sensors at this age will be getting inaccurate): Air intake Sensor, MAP Sensor. One step colder plugs.
Replace your engine mounts with the Corteco high-hp/torque version when you put the headers in.
Optional:Buy a crank sensor its cheap and easy replacement, and you eliminate the risk of going to start your car one day and it just wont crank, at this age and in TX i bet its getting cooked.
Old Feb 21, 2018 | 02:46 AM
PieRat's Avatar
CLS55
Oh yeah then definitely you can do it all yourself. I'm a newb at mechanic stuff but through the DIY's online am able to do most mods myself, only problem is finding the tools!
