Air leak
Old Mar 26, 2018 | 06:01 PM
kindya.hill's Avatar
CLS55;S63;W12;F450
Air leak
Change supercharger over the weekend got everything back together now there is a whistling noise coming from the second Injector on the passenger side I can spray around the injector and the noise will stop can’t figure out if it’s coming from the gasket under the supercharger Or the injector it self changed the injector o ring and it’s still doing it any thoughts or suggestions
Old Apr 25, 2018 | 12:06 AM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
If you changed the gasket under the supercharger money is on the gasket. If injector were leaking you’d have a miss. Get a vacuum gauge and hook it to the intake. It should be steady 25 -30 inch. Less than that or fluctuating gauge means you have a leak and since it isn’t missing im betting its the gasket. Try spraying some carb cleaner around the gasket near the number 2 injector. If it’s gasket you’ll hear a slight change in rpm and the whistle will stop. Good luck.
