Need wheel and tire advice for 20' wheels
Old Jan 16, 2019 | 02:25 AM
ta72's Avatar
2006 CLS55
Hi,
I would like to know if these 20x9 et28 and 20x11 et37 wheels will fit and work on my cls55? If so, what tire set up should i use? Any spacers needed?
Need advice from wheel experts.
Old Jan 28, 2019 | 02:57 PM
ta72's Avatar
2006 CLS55
My HRE is installed!
Old Jan 29, 2019 | 03:38 PM
AudiologyVA's Avatar
W210, W164, W220, W222
Damn!! Nice choice of wheels.....Kudos, the car looks great
Old Jan 30, 2019 | 12:36 AM
ta72's Avatar
2006 CLS55
Smile
Thanks Brother!
Old Jan 30, 2019 | 11:22 PM
tphss's Avatar
W204 C63 P30 / C190 GT S
Nice congrats! What tires did you end up going with?
By the way, are you on coilovers?
Old Jan 31, 2019 | 02:00 PM
ta72's Avatar
2006 CLS55
Thank you! Tires are 245/35/20 fronts and 295/30/20 rears. Pirellis P Zero. No coilovers. Still on airmatic.
Old Feb 3, 2019 | 12:52 PM
oneslow55's Avatar
E55 amg
You can still go more aggressive as a 11 can take a +30 easy with a 305..Some peoples flush is not a true flush ..
Old Feb 3, 2019 | 12:53 PM
oneslow55's Avatar
E55 amg
your speedo is off with that tire setup and you lucky your not getting esp codes..30 front and 30 rear is made on a 20 inch tire unless you use a 305 then a 25 would be like a 305 25.
Old Feb 3, 2019 | 02:10 PM
ta72's Avatar
2006 CLS55
Ive been driving on the freeway and no lights. I guess i have to wait and see what happens.
Old Feb 3, 2019 | 02:14 PM
ta72's Avatar
2006 CLS55
Might have to go with 285/30/20 on the rears for my next tires.
Old Feb 3, 2019 | 02:53 PM
oneslow55's Avatar
E55 amg
You might get on wot or turns..285 you can go with a 30 ..
Why drop down to a 285?? is that a 11 inch rim if so it will over stretch and look like doodoo,
Old Feb 10, 2019 | 11:15 PM
ta72's Avatar
2006 CLS55
I think 255/30/20 fronts and 305/25/20 rears would be idea on my next set of tires.
Old Feb 11, 2019 | 08:02 PM
lost27's Avatar
CLS55 AMG
The car looks great! Congrats! What offsets did you end up settling on? Do you get any rubbing at all up front when turning lock to lock or over bumps? Any rubbing at all in the rear?
Old Feb 14, 2019 | 07:53 PM
ta72's Avatar
2006 CLS55
20x9 et28 and 20x11 et37 with 3mm spacers all around.
It will slightly rub when turned over bumps and driveways. I just remind myself to raise it when going over bumps or driveways.
