Conductor plate stuck. Please advise
Old Feb 18, 2019 | 01:44 PM
suprat13's Avatar
cls55 amg
I have an 06 CLS55 with the standard faulty conductor plate symptoms. All the valve body bolts and the electrical connector have been removed but the plate will not
detach from the tranny. I've searched numerous threads so i apologize to the search police if something was over looked.
Old Feb 18, 2019 | 04:19 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
Have you removed the bushing from the conductor plate? It’s the part that the harness plugs into its held on by a 7mm bolt
Old Feb 18, 2019 | 04:37 PM
suprat13's Avatar
cls55 amg
Yes sir the bushing has been removed.
Old Mar 15, 2019 | 03:13 PM
ambit's Avatar
09 CLK550
I removed the valve body out of my CLK55 (which I think is the same 5sp transmission) twice, both times it basically fell out after removing the 10 x t20 torx bolts
https://mbworld.org/forums/clk55-amg...ml#post7415590
https://mbworld.org/forums/cl55-amg-...ml#post7063434
Old May 5, 2019 | 08:23 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
It may be warped from the heat expansion and contraction. If you are replacing it and all solenoids are removed then just “persuade” it out.
