boost and intake temp question
Using a car scanner app.
Intake manifold pressure of 3.9 at 70mph cruise and then 10.5 +psi at loaded trottle to about 95mph.
cruising intake temp is at 109
Is this normal numbers?
What would my intake temp be like with split cooling?
Thanks.
I wouldn't bother splitting your cooling unless your doing another cooling mod like adding a trunk tank or under hood tank. If you were installing the HE, sure, split the cooling while your in there, but doing the job on its own shouldn't make a huge difference from what people say.
Thanks.
Agree, do not split , unless you plan to add alternative cooling source.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
