Battery light on please help
I checked the battery voltages and they seemed fine. When I checked the charging it was low so I decided to replace the voltage regulator on the back of the alternator.
I started the car up drove for about a mile and what do you know the damn red battery light came on again. I checked the batteries they were good, and charging seems fine too. On the dash it shows that it is steady at 14-14.1 at idle. However, when I drive I see a dip in the charging going down to the 12s then back up.
I realized that the light will only come on after going past 3k RPM the convenience features will shut off. But the tricky part is that the light will go away and the features will start working if I keep it under 3k RPM.
I tried looking for any posts about this and they were all over the place including the battery control module.
Please help me out fellow members.
A shame that at 67k having these issues.
However, one more thing at play here is the Voltage Regulator is an aftermarket one. I wanted to put the OE Bosch one but had to order at dealership. My local part supplier only had aftermarket.
I may order from stealership and put OE to see if that’s it.
I ended up just buying a new Bosch Alternator. Don’t want to risk changing the voltage regulator to end up finding out I’ll need the alternator.
what gets me is that the charging seems fine at idle and when the car is cold it does it closer to 3k RPM. when the car warms up then it starts to do it at lower RPMs.
hopefully it’ll be sorted out soon. I’ll keep you posted.
I just changed the alternator today and the problem is resolved. It was the alternator after all.
Thank you for the responses.
Usually I drive her about once a week. Use the Prius for commuting lol.
lol have to balance my gas mileage CLS is horrible and my Prius I average 48-50.
