Headlight Question
Sadly, the W219 model headlights dont have tab fix kits (w211, w218 and others all have them, so **** out of luck), and fixing the tabs is a truly last resort - as it seems the tabs have metal rods/tough wires in them from the factory, and managing to fix them to the factory position would be an utter frankstein of a job, if even possible - as the weight of the huge headlight rests solely on those 3 tabs.
Will probably try the swap next week. OP, if you have tried the swap, how did it go? If not, ill let you guys know how it will end up.
We have these rubber like windshield/headlight seal fixings all over the place here (referred to as moose drool), I did the projector swaps a year ago with a friend, so hopefully with a decent heatgun the headlights wont be a nightmare to open up.
Only thing I am wondering right now, is the self levelling motor - because the halogen unit seems to have a manual bit installed there. The housing looks to be the same from pictures I sourced, but cant be sure as of now - hopefully the new unit arrives next week and I can disassemble everything and the mounting points fit.
I will photo and document the comparisons of the light interal bits and mounting points when I gut them both, and ofcourse the end product, if it is possible to finish.
Thanks for the inputs!
marked with red circles are where to cut the holes. bottom holes actually have an outline, so thats easy. middle one requires more handywork.
Will try to finish tomorrow, as I have no file at hand right now.
