Correct Fuel Pump part numbers CLS55
Old May 30, 2022 | 03:36 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Exclamation Correct Fuel Pump part numbers CLS55
I just recently read about the fuel system for the M113k which needs attention every now and then. I know for a fact that my 2005 CLS55 is still running with the factory fuel pumps (186k kms). I was searching for the correct partnrs, but havent been able to get a definitive answer.
Who is able to help me?
https://mbepc.net/en/1/fg/cls/66w/219376/0/47/015
Im pretty sure this is part is correct...A2114700000 (the dual pump setup). But the other part with the filter and pressure sensor? Please correct me if wrong!
Old Jun 6, 2022 | 07:11 PM
Received confirmation here: https://mbworld.org/forums/w211-amg/...-question.html
Originally Posted by bbirdwell
You replace everything. While your hands and arms are soaked in gasoline. Three bars on the fuel gauge at the maximum or you run the risk of fuel spilling out of the tank.
And the 211-470-00-00 part number is a set of dual fuel pumps. You must use the third-gen fuel filter/regulator with it plus adapter cables. See my answer in your other post.
-211-470-00-00 Fuel Delivery Module (dual pumps) $411
-211-470-64-94
Tank Inner Module (actually filter and regulator) $489
-211-471-05-79 Fuel Sender Seal x 2 $34
-211-440-05-07 Cable Harness adapter for filter/regulator $15
-211-540-07-00 adapter cable to dual fuel pumps $15
-203-997-04-81 foam cushion $1
