p0016 an p0017 codes
Old Feb 10, 2024 | 01:38 PM
akitaburhan's Avatar
2007 CLS 550
Hello dear members, I am writing from Toronto, Canada. I have a 2007 CLS 550. A while ago, the engine light came on with error code p00016. I replaced the Position Sensor and 1 Chamshaft Adjuster Magnet. Then error codes came as p0016 and p0017 together. Do you think the other Adjuster Magnet should also be changed? Or should the engine cover be removed and the crankshaft and camshaft aligned? Ayn idea? Or do you know well mechanic in GTA area?
Old Feb 10, 2024 | 01:51 PM
Gixxer75008's Avatar
2006 Mercedes Benz CLS500
Good afternoon I'm new here and this is my first post and thank thank you for the join.So I was wondering if anyone could help me out or put me in the right direction so I have a 20006 CLS500 its throwing code P2767 Input/Turbine Speed sensor B Circuit NO Signal on my cheaper scanner took it to friends shop his scanner says no communication TCM. So went to Mercedes dealership and my friend cleared codesso the couldn't find anything but the did find a problem with my SBC Breaking system and they replaced that for free so car was running good shifting no problems breaking good for about 300 miles now no problems so to go out ready to leave and boom check engine light on stuck in limp mode and code P2767 if any advice or ideas greatly appreciated thanks new member. If u find any answers please share with me and I'll do the same good luck
Old Feb 13, 2024 | 04:29 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
That error code seems to point at the speed sensor, which is located on the conductor plate of the transmission valve body > https://mbworld.org/forums/e-class-w...ult-p2767.html
I have more pictures in my build thread, follow the link in my signature
