Angling up driveways and traction control?
How many of you with or without lowered suspension angle up driveways and set off your traction control. I seem to be getting that often when slowly going up fairly steep driveways at an angle and adding a little bit of gas to get up the rest of it. It feels like crap cause it has this grinding kinda noise/feeling coming from the rear, which I guess is from the car sensing that one wheel is light and traction control does its work.
Juss curious how often it happens to others. I probably shouldn't have to go up too slowly cause the car isn't too low, but with 19s and the tires being thinner, it feels like crap going up any faster cause the egde of driveways are usually raised pavement from the rest of the street.
when this happened for me, it was actually one of my rear tires lifting off the ground putting more weight on the grounded tire causing it to slip
i found that my car wasnt actually as low as I thought and to go in straight but slowly
It happens to me too.
It happens to me all the time. Since my car is lowered with H&R suspension (and 19" wheels too), its seems to kick in readily when angling into a driveway. I can hear the ABS being applied to one side of the rear and the car just won't move forward...
Yeah, I've been trying to go up less angled and it works. That only really works for entering driveways from the opposite side of the street though. Entering the driveway from the same side of the street juss forces us to angle anyways. Guess that juss means turning the steering wheel some more to try to get the car straightened up as possible by the time the rear starts going up. It's not a big deal, just curious how often people were experiencing this and possibly if there was something wrong with the car (which there isn't since it happens to others).
Happened much less before the suspension upgrade, so lowering probably increased the chances of one of the rear wheel lifting slightly and allowing the car to sense that it is lighter. I'm running the same setup as Auxo and Idrivefast, so the lowering might really be contributing.
careful though, try to turn in as straight as possible because the "lifting" you and I experience will also result in uneven tirewear, which is a *****...
