evosport V-6 Headers (C240, C320 and C32)
As for the software, we do prefer and recommend only Powerchip. You can find cheaper solutions, but you will not find a better one - PERIOD. Kleemann does offer nice products, I have just not seen anyone put out the reliable gains and offer the kind of support that Powerchip offers. Also, realize, that ONLY Powerchip is tuned for CA91. All the others you will be looking at are based on European RON98 or US93.
Further, if you go with Powerchip, you can get a file specifically tuned for the header. This is a large advantage, as you must realize a header without a specific tune will make the car run lean. More air flow, smae fuel, equals a lean condition.
On a naturally aspirated motor, you are better of going with hardware mods first, then mating in the right software. You shoud see more gains at each step that way, giving you a better value.
Here are the differences as we see them:
1. Improved flow through merge collector
2. Ceramic Coating
3. Better Value (less costly)
4. Made in the US (availble with zero to minor delays - big problem with SS)
5. Mercedes tuner built - so you have better vehicle specific support
Thanks,
Brad
Hopefully someone will bite. If not, like I said, I'll probably drive down myself.
I agree that it is ridiculous for the benzworld site to moderate the forum like that. Look at how I had to post my message. Brad, thanks for not being **** like the other site.
Like all of our shorty headers, the installation of these is a direct bolt-in and does not impact the function or placement of the cats. They are also coated with our NASA-Spec True Ceramic Barrier coating (which will show up to a 120 degree drop in radiated temp from the header)
Headers feature:
- Single piece 3/8’’ flange design for leak free installation.
- Billet Steel CNC one piece collector flange.
- 1 5/8’’ primary pipes.
- Aluminized steel construction with 2000F HiTemp Coating.
- 10-15HP gains on C240s and C320s.
- 20-25HP gains on C32 AMG.
Introductory pricing $1495
ho;y crap, why so much?? i noticed you prices are waaay too high - on other items as well. such as pully's, i found them $200-280
