Got Camber?
But could we drop it so we don't hi-jack the whole thread?smgC- do you have correction bolts in there? You could use the correction bolts then use washers on the lower 2 bolts of the wheel carrier. It's jury-rigged but is a "trick" a lot of people use.
But could we drop it so we don't hi-jack the whole thread?Made me think of that picture I saw over on eBaums. no need to get your panties in a knot, that picture is quite on topic considering it refers to smgC32's post. dang chill out people.
As for the correction bolts, I put them in and were only good for about another .25 degrees and I turned them in all directions. Shimming out the lower strut attachment point is the only alternative at this point. For safety reasons I would like to get replacement bolts that are longer by the same amount as the washers are thick. Get those camber plates going!
The camber plates. This could be made a lot simpler if someone was interested and lived near El Dorado Hills, CA. Then we could provide measurement to Jeff in the flesh
I need a vacation, but that's a long drive from Maryland.Question; Why don't you prep the C32 and enter the USTCC series out there?
Rick, not sure where you're going with that, but no they wouldn't.
Tom
What if we could adjust camber from inside the car?
You give me an idea for a sitcom, "Vraa's big freakin Sig!"
Tom
Please let me know if you still have those spacers.
Sorry, i sold them when i sold the wheels.
You may not have to roll the fender with that though, but i cannot say for sure.
For the rear? thats the first time i heard they needed them for the rears. You do have them on the fronts also right? My C230 with 19x9 SSR GT3 with 265/30/19 tire rubbed with no spacer on the rear.
What if you could though, change only the camber.
Highschool physics all over again
Thanks,
Tom
