Oil Change DIY?
Old Apr 1, 2005 | 08:21 PM
saksiri's Avatar
2002 M3
Oil Change DIY?
Hi,
I'm not familiar with the C32 but my friend has one and he wants to do an oil change.
I've done a search but haven't found a really conclusive DIY with the following information:
- Where is the filter located? Does it require a special wrench?
- If I'm using a topsider, how do I get the oil out (I've heard there is no dipstick tube)?
- Where do I fill the oil?
- What is the torque for the filter? (hand-tight like some cars?)
- How many qts of oil and what viscosity (this is in northern california)? I've read 7.5 qts of 0w40
- If I want to drain the oil directly from the pan, what's the size and torque of the drain plug?
Any help would be appreciated. Thanks!
Old Apr 2, 2005 | 11:29 AM
Narcissus's Avatar
2001 C240 Tectite
You might want to drain it from the plug, the filter comes with a new washer and 3 seals for the filter, the filter is located under the engligne cover, can't miss it. the torque is 25 nw and you can buy a special tool to unscrew it or rambo one yourself.
Changing oil is the same for a honda or mercedes. nothing special...
