Best Coilovers and Price...
...besides, you can probably pay for your coilovers w/ one hand of poker out there or pull of a slot :p
Bilstein PSS9s is good as well. About the same price.
Both are notably stiffer than H&R coilovers. If you want close-to-stock ride comfort, H&R coilovers are only COs for you.
I have the PSS9s on my car, it's great and all but the ride is definitely not soft, even with dampening set to the softest. o yea, the KWs and Bilsteins both have adjustable dampening + rebound + height etc.
H&R only has height adjustability, hence the low 1,200 price tag. So it all boils down what you need and how you drive your car
Recommend upgrading your sway bars too after the suspension upgrade...better if u do it all at once =) Good luck~! Modding never ends, one mod leads to the next! haha
Also living in Michigan w/ our pothole'd roads, they are very comfortable. I actually (which contradicts the previous post) have found them MORE comfortable than stock when set to Full soft up front and about setting 3 on the rear.
When I say more comfortable perhaps Its because I dont get that intial bone jarring I used to get w/ the stock set up when I hit a pothole
anyway the above pricing seems to be right on.
