want to lower front?
Old Aug 1, 2005 | 06:17 PM
SUNILP's Avatar
2015 E250D
I have the c32 amg suspension setup on my c320 and don't like the front since it's a bit higher than the rear. Which suspension can I use to lower the front the same amount. I believe the new C sport sedans are even all around.
Old Aug 1, 2005 | 08:01 PM
Renault78law's Avatar
2003 C32
I'm not sure about the 320, but in the 32, the car is actually level. The front appears higher because there is a greater fender gap. If you want the car to appear level, you have to lower the front more than the rear. Something like Renntech will do the trick, but even still the fender gap will be slightly larger in the front than the rear.
Old Aug 1, 2005 | 09:25 PM
Blake P's Avatar
'09 A4 S Line
Sunman, I think your best bet would be to purchase the C320 sport suspension for your car if you want to keep it OEM. Otherwise, there are many aftermarket coilover setups that will achieve any desired height. Knowing you, I would assume you want an OEM solution though.
Old Aug 2, 2005 | 03:08 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
get some RENNTech springs and you are set.
