C32: tail becomes unstable under heavy braking
I never had this fear with the Mitsu Evo. Is this the nature of C32? Is there problem with my suspension mod??
All cars will have the tailend become light under braking. The C32 is only evil under heavy braking when the car is put into "dyno" mode with all ABS/ESP off.
All cars will have the tailend become light under braking.1) First, I apply maximum braking before the turn.
2) Gradually reduce braking and start to turn steering, as the car approach the turn.
3) Once into the turn, foot off the brake and ease on the throttle.
4) Start to increase the thorttle after the apex.
5) Maximum thorttle exiting the turn.
Step 2) is where I fear the tail might snap.
side note, if you wanna break loose, thats the time you wanna go fulll throttle!
The point of trail braking is to make the car turn in quicker and more completely so the feeling of the rear wanting to step out shows that the is turning in quickly. That really is what you are looking to have happen so next time just try to ease of the brake a little sooner and more smoothly. The transition from brake to gas is very important and a smooth and quick foot could help with this issue.
The camber chagne of the wheels as the car goes from braking to gas could be an issue and that is where these rubber bushigns and their deflection could come into play. Replacing all the rear links with heli joints would eliminate the play and make the car far more stable in such activities.
hope this helped
I can still make the C32 understeer if I go around and around in circle, increasing speed gradually, the front eventually break loss. There's no weight transfer in this case.
My tires are 80% new, pressure is F36/R34.
I tried my friend's stock E46M3 at the same turn same speed(210kph slow down to 130kph and enter). His tail was a lot more stable during the braking and the initial turn in.
The rear bushings provide a lot of play in the suspension and under heavy braking wiggle way too much. The car gets light and starts shaking. This is repeatable every lap from 140mph to 90mph turn entry. Trail braking must be used with caution in the C32. If you engage dyno mode, things get much worse when trail braking and the car will snap around without notice.
"...So I decided to have Bilstein stocks and H&R springs installed...
Does the C320 H&R springs (part number 29392)fit for C32 AMG?...I noticed the rear is too low and I added one more spring pad 10mm for the rear..."
Is this set up ok?
What is the measurement from the fender lips, front and rear, to the center of the hub. I have found a good compromise for track and street to be 13.25-13.50" in the front, and 12.50-13.00" in the rear. This will allow the front to clear concrete parking stops and steep driveways and still provide for better handling and looks. Go much lower and you will blow your front struts and not necessarily increase handling.
Eibach sway bars for front and rear.
H&R springs front and rear.
Bilstien shock for C-Class front and rear(added 10mm pad in rear).
The simplest thing to try is to get the H&R coilover(adjustable height & fixed damping) but keep the sway bar, think that might help?
Put the thinest pad in the back to lower the rear. This will level out the car a bit and provide a little less weight transfer to the front under heavy braking. The only thing left to to is a rear sub frame modification.
I can floor the throttle right after the apex in a AWD car.
What good is RWD?
After reading everyone's reply, I conclude that my super thick Eibach rear sway bar is causing the rear to become unstable when trail braking into a turn(weight transfer).
I plan to get some coilover and stock AMG swaybars.
