Grenade a C55 motor?
Is this a major problem or just a software problem that is not properly shifting the trans? I am afraid that at some point I will grenade the motor. I will take the car into the dealer (reluctantly) but wondered if any of you have experienced this issue. Thanks for the help.
Just lend the car to your mild driving partner and when you get back into the drivers seat you will notice that it drives totally differently.
That being said .... did you try giving the "+" button a nudge ?
If so, there is no cure.
On the 99 mustang the ECU/PCM runs at only 16MHz and handle both Engine and auto trans. The Audi S4, uses two seperate computers.
Has the ECU/PCM been flashed by an aftermarket company?
Don
MBUSA for their part, tried to solve the problem on and off (I didn't mind my car being a test mule but I didn't want it to live in the shop either) for a couple of years by replacing (with upgraded parts where available) ECU, TCU, shifter, valve body and other misc parts. In the end, the problem only improved marginally. MBUSA and AMG finally decided last year to give up since "the problem was insignificant, non-damaging and effected such a small number of cars.
MaxC55- I have, on occasion, experienced what you are describing. However, my interpretation was that the trans is shifting from 1 - 2 as normal, breaking the tires loose (ie: losing traction) and then ESP intervening and causing the momentary cut-out. It happens most pronounced on slippery or glazed asphalt surfaces. Are you certain that you're getting the cut-out before trans shift, and not after?
I have experienced this exact scenario as well. It only happens from gear 1 to 2 and only when I "floor it" from a stop and do not ease on the accelerator. It will run at red line for a second, then cut out momentarily until the engine upshifts to 2nd.
I think what happens to the car when it goes from 1-2 is that it needs to cut the fuel altogether in order not to break the tires loose. But that is mostly when there isn't quite a neckbreaking snap like you have described.
my .02
I only hope that I do not slam a valve into a piston the next time it happens.
Try a full throttle start (with the selector in Drive) through the 1-2 shift then slow down to about 20-25MPH and floor it again so it downshifts back to first and hold it until it shifts back into second. This is the method I use to duplicate the problem with or without ESP on.
BTW, the pistons won't hit the valves. That's one reason why they cut the fuel to prevent the engine from overspeeding and floating the valves.
It's really annoying when you are just rolling through a stop sign and the transmission acts all aggressive and such when you are driving normally.
I'm going to the dealer tomorow and maybe I'll ask someone about this.
Scott
