3years, any ODPS/engine failures?
Audi C7.5 S6
It's been about 3years, since the Evosport ODPS kit came out, are there any reported Evosport ODPS/engine failures? If we have not had any yet, then the setup must be somewhat reliable.
I have been thinking about it for awhile and have been considering which is the most reliable, Renntech, Evosport or ASP? They all seem to have some drawbacks. The Evo's probably have the performance edge, but may not be as stealthy as the ASP or Renntech?
So does anyone have some opinions on this, now that there is some history
on these pulleys ?
on these pulleys ?
W211 E63
Originally Posted by wawy
Good question. I too am curious as I'm considering them for my first major upgrade.
W211 E63
Originally Posted by amgme
My tensioner pulley was going south. Evo sent a replacment for $55 bucks.
I think it was my tensioner pulley as well, mine was one of the very first kit that was produced.
Audi C7.5 S6
idler spins pretty fast (small)
Sounds like the Evo pulleys have been relatively reliable. The crank pulley
would be a costly problem, if it was not reliable.
The idler spins pretty fast (small diameter). On other cars, the idler/tensioner is generally the weakest link. Proper tension on the idler is pretty important, especially for tracking tension/slack for acceleration & deceleration. If it is not responsive enough, one could throw a belt.
So did the bearings on the idler get ratty or was it the pulley surface?
W211 E63
03 C32AMG, 05 ML 500, Ducati 998S
My idler tensioner went bad also. The difference for me is that the MB dealer replaced it for me. I then drove to Evosport to have Vadim check it out whether any of the ODPS components have been tampered with...it checked out ok. The tensioner pulley was making rattling noise (per dealer, I personally did not notice it). Had the kit for 2 years, 16000miles, thankfully no ODPS related issue except for the idler.
Originally Posted by Vadim @ evosport
85,000 miles and counting.
Very first kits had weak bearing in small tensioner. All new kits have upgraded bearing.
Speaking of upgraded items in the ODPS kit, I would like to replace my window washer fluid tank to the updated layout where the lower hose goes into the side of the tank as opposed to the bottom of the tank. Although I am careful when parking the car, once in a while the some parking stops are high enough and comes in contact with the lower fitting and hose coming out from the tank (not to mention the visual "ques" a dealer tech would find when they inspect underneath the car). I believe that the updated layout does not involve trimming of the bottom engine bay cover and therefore is more discrete?
E55, C32, ML320
Originally Posted by AMGod
Someone reported a front crank seal going out without any definitive proof that it was caused by the EVO kit.
Since then, I noticed a thread regarding the latest pulley under development by Evo:https://mbworld.org/forums/showthrea...ht=m271+pulley. I find it interesting in that it includes a dampaner. That seems to substantiate the dealer's position. I have an e-mail into Evo as to whether they will be updating the design of the C32 pulley.
More to come...
SLK32
Originally Posted by blando
I was the one who reported the front crank seal going out. The master tech at the dealer says it's the design of the pulley (that it lacks a dampener) and Evo says that the dealer is wrong. Unfortunately the thread that discusses this dampener issue was deleted by Evo, so you won't be able to read through it. Thanks to all who provided their insight in that thread, especially MarcusF who gave a very informative professional opinion.
More to come...
More to come...
07 SL550; C32 (sold)
Audi C7.5 S6
idler bearing
So I guess, the idler bearing was the weakest link on the old Evo ODPS, but it is apparently fixed in the new kits?
Has any of the other brand pulley kits had any pulley failures on the C32?
Does the Evo ODPS use the stock belt or some other than stock length?
'14 428i M-Sport, '02 C32 AMG
i think it would be beneficial for users to keep on providing any update on their experiences with aftermarket pullies, since more miles have been accumulated on pullied c32s. i would appreciate any pulley users commenting on how they have been holding up so far. thanks guys
