need help! Rubbing
Silver 2002 C32, Silver 2006 CLK 350
need help! Rubbing
well I got my rims and tires on..... My rear 265/30/19 9.5 is rubbing when I hit a bump no passengers on the back. I was going to have the car lowered but need some advice....
can I have it rolled?
is my shocks bad?
or do I need to have it cambered?
pls help....
thanks
is my shocks bad?
pls help....
thanks
2006 E55
lowering it will probably help since it will add some camber to the rears. Mine rubs when lowered and I got passengers going over bumps. Im not concerned with the area rubbing because its just the plastic body part, and I hope it will just wear down with time
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Originally Posted by Blake P
What's the offset of your wheels? With the correct offset, this setup should not rub. You can always roll and/or shave the fenders.
is not yet completed
i dont rub either.. and my rear is pretty much tucked...its prob the offset.. or you can roll and/or shave your fenders..and it might be the tires have a big part of it also
Originally Posted by Trekman
sup Ace hay do you know anyone that can roll my fender?
MBworld Guru
white and whiter
depends on your offset for the rims.
The TSW has more aggressive offset because it has a bigger lip in the rear.
My own car's rubbing but my friend's car doesn't.
MBworld Guru
white and whiter
frank what do you think I should do to fix the problem?
Originally Posted by FrankW
if you are on stock right now, it's 99% rubbing on the tabs where the bumper meets the fender. Just have your shop shave that part off you should be fine.
MBworld Guru
white and whiter
the palstic molding correct? if I lower my car do I need camber links? and do you know where I can get them?
alignment's needed after you lower the car btw.
ok frank thanks I will try it tomorrow..... can sleep cuz im kinda pissed that my car is rubbing now...
MBworld Guru
white and whiter
MBworld Guru
white and whiter
with your new rims or the old ones you have?
The Axis didn't have any problem with rubbing at all until I went stupid and put on the spacers.
