anyone without teleaid??
a car that can't do the throttle reset.
i have that stupid '1 malfunction' in my cluster cause i don't want teleaid.
mbusa says it cannot be deleted. dealer says only mbusa can do it. anyone know if there is a way to get rid of it???
MBworld Guru
white and whiter
i haven't paid for teleaid for the past year...the thing indeed doesn't work anymore, but no error msg. You just get the "you are not dialing from an authorized location please try again" reply.
MBworld Guru
white and whiter
wtf!?! so i guess it is possible to not have the malfunction.
my suggestion is to call the 1800 mb roadside number and tell them about the teleaid error msg and ask them to turn the error msg off for you. they'll probably ask for your VIN number etc and varify your name
yup. my car came with teleaid for the first couple months for free i believe, so you had to activated it. once it's activated the error msg will stay away even after you cancel the subscription. I cancelled mine after 2 1/2 years with out any use for it.
2020 BMW X3M Comp
I like your suggestion and will call tomorrow. If it can't be removed, I might suck it up and pay for another year.
Originally Posted by NY C32
I get that annoying malfunction warning too! I let my subscription run out, the malfuction popped up and won't go away. I can't stand it and the dealer told me the same thing, they cannot disable it.
i have the same malfunction...usually appears during the first start up of the day and then is gone until the next day
i have many things to spend 300 on and this will not be one of them!
cb in stl
cb in stl
Originally Posted by amdeutsch
Buelwinkle had a writeup on this in the regular W203 forum. Might search for it.
Originally Posted by dragonAMG
I never activated the 1st free year... lucky me.... I don't have to worry about this.
The runaround
I had an error, and the dealer removed my Teleaid error message.
You would think that after several years of looking like fools when the customer knows better than they do, the dealerships would learn....
I found these notes
In stardiagnosis :-
Control Units -> Info. and comms. -> ICM -> Control Unit Adaptations -> Version Coding -> Optional Equipment
In the optional equipment menu you can set the following
to present or not-present depending on what you have
AUDIO, Tele-aid, Cellular Telephone, Trip Computer, Navigation
I found these notes
In stardiagnosis :-
I found these notes
In stardiagnosis :-
I found these notes
In stardiagnosis :-
