Front suspension squeaks?
Old Dec 24, 2005 | 08:04 PM
stevec32's Avatar
2007 E550 and 2007 335i
I have a 2002 C32 with 56,000 miles. Just recently developed a squeak in the front left suspension when going over any small bumps especially when cool (like 50 degrees or less). It is not the seat it is outside. Any ideas ??? Other than this it still drives very well and is still tight when pushed hard. I have the extended warranty but I am unsure what would be covered and not covered. FYI It has been a good car only broke down once in 4 years. An alternator failed, flatbeded car and a loaner car given. Thanks
Old Dec 28, 2005 | 12:10 PM
RapidG's Avatar
C32AMG
Have the front sway bar bushings replaced. Nearly all the 02's had that problem. When the bushings are replaced, the noise goes away.
'02 C32 AMG stock
'85 380SL
Old Dec 28, 2005 | 02:47 PM
RA72825's Avatar
'02 C32 AMG stock
'85 380SL
That's affirmative. It will sound like a brand new car when you replace the bushings. In other words, that crunching squeek that you prolly got used to hearing will be completely gone. s/b warranty item
Old Dec 28, 2005 | 05:08 PM
A-Pod's Avatar
'02 C32 AMG
i can confirm this. had this happen immediately after i bought the car (got it used from dealer) and took it in there to get bushings and sway replaced...under warranty, no problem. it took care of the mouse under my wheel wells
Old Dec 29, 2005 | 09:16 PM
stevec32's Avatar
thanks for the replies
Thanks one and all!!! Bushings and maybe a sway bar after the first
Hope everyone has a safe and sane new year this is a great forum.
stevec32
Old Dec 30, 2005 | 08:33 AM
Carl AMG's Avatar
2002 C32 AMG Orion Blue Charcoal/Blue
Please note that the fix requested should be both the sway bar endlinks and the sway bar bushings. The sway bar itself should be fine. I know some people have had sway bar endlinks fail although I doubt they are the source of the noise.
My dealer took care of this problem for me and replaced both parts.
Old Dec 30, 2005 | 10:53 AM
stevec32's Avatar
noted
Thanks Carl AMG
I will now be well informed thanks
stevec32
