Anyone know how to manually eject a CD from COMAND?
I had one stuck and the drive had to be opened up and the disc removed. The cd mechanism was mis-aligned which caused the problem. Good luck.
2003 C32, 1999 E320 Wagon
Follow up:
The dealer replaced the COMAND under warranty. I was kind of bummed that they replaced it with an identical unit, I asked for an upgrade to a DVD-based one but no dice.
Originally Posted by Stack_Hardhouse
Follow up:
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
Originally Posted by johncl
You can't do a DVD based in your car without spending many thousands of your dollars to convert the whole electronics system from D2B to MOST. ![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
Glad to hear that you were able to get a new COMAND. Just curious, how long did it take them to replace the unit?
EDIT: I should clarify that the turnaround time was 24 hours. I don't know how long the actual work took.
